Author Topic: Looking for "000" function on keypad  (Read 2436 times)
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« on: Sat, 03 January 2015, 07:55:06 »
Hello everyone.
I am accountant. And I type "000" much more times everyday.  Now I am using keypad as picture below:
Numberic keypad by quochung19890409, on Flickr
But I love mechanical keyboards, so I wanna buy mechanical keypad which have that function.
Who know about it? Please help me
Thank you
« Last Edit: Sat, 03 January 2015, 07:58:42 by quochung1989 »
Offline iFish
Re: Looking for "000" function on keypad
« Reply #1 on: Sat, 03 January 2015, 09:52:49 »
probably have to make your own or modify an existing mechanical 10-key with a teensy microcontroller.
Offline Matias
  • * Commercial Vendor
    • http://matias.ca
« Reply #2 on: Sat, 03 January 2015, 10:02:15 »
If it had an Fn key that your thumb rests on, and Fn-0 did 000, would that work for you you?
Something like this...
Offline FrostyToast
  • Litshoard
« Reply #3 on: Sat, 03 January 2015, 10:03:26 »
Can you not just get something custom that you can program yourself?
Quote from: elton5354
Offline Hzza
« Reply #4 on: Sat, 03 January 2015, 10:04:17 »
Isn't there a DIP switch on the Topre numpads that changes the 00 to 000?
Offline ezrahilyer
« Reply #5 on: Sat, 03 January 2015, 10:22:29 »
If you are on windows use Autohotkey to make a script for that. You could make it default to 000 and if you just wanted a single 0, hold the key down for a second and make an event for that.
Offline ComradeSniper
  • HHKB Pro
« Reply #6 on: Sat, 03 January 2015, 11:59:23 »
Yep.
  • Frenzy Classic.
« Reply #7 on: Sat, 03 January 2015, 20:10:08 »
Oh I missed more group buy, so I 'll find it in classified. Thanks for your advice.
Yeah thank for your help. I 'll try
Oh I don't know that :)
Yep.
Oh thanks :)
  • Frenzy Classic.
« Reply #8 on: Sat, 03 January 2015, 20:38:01 »
I studied about Keymap software of KMAC Pad & LightPad. They seems not have "000" function, so I 'll go to buy Realforce Numpad.
Thanks to everyone :)
