Author Topic: Transformers / Autobot / Decepticon backlit keycaps  (Read 6026 times)
Offline MrFex
« on: Sun, 04 January 2015, 13:35:25 »
Hi everyone,
I've been desperately looking for transformers backlit keycaps, couldn't  find them anywhere except a few pictures online that seemed to point nowhere. I finally found them, will post back upon arrival!
I also got a few others, hope you like this link:
http://www.aliexpress.com/item/Keycaps-Key-caps-for-backlight-Backlit-mechanical-Gaming-keyboard-R4-ESC-Translucent-dota-2-cs-zerg/32236093772.html
Greets
Offline twk
Re: Transformers / Autobot / Decepticon backlit keycaps
« Reply #1 on: Mon, 05 January 2015, 12:44:26 »
Nice find :) Thanks for sharing!
Offline Zidail
« Reply #2 on: Thu, 15 January 2015, 09:14:28 »
If you're in the habit of using taobao, you can also pick them up for 10RMB.
Just use the key words "键帽 狂派 博派" (which translates to "Keycaps Decepticon Autobot") and you should be able to find them too.
Offline MrFex
« Reply #3 on: Sun, 18 January 2015, 14:13:39 »
Very appreciated. Thanks!
Offline twk
« Reply #4 on: Thu, 22 January 2015, 13:03:42 »
Have you recieved them yet?
Offline MrFex
« Reply #5 on: Sat, 31 January 2015, 13:06:31 »
Hi, just got them today! They are awesome looking, good quality! Very pleased!
If anyone would like to see some pics just let me know.
Offline twk
« Reply #6 on: Sun, 01 February 2015, 14:43:24 »
Yes,  please! I'm thinking about buying the same ones  :)
Offline MrFex
« Reply #7 on: Sun, 01 February 2015, 15:25:53 »
Here you go friend ... the pictures didn't turn out great because I had to take them at night time!
What do you think... ?
89419-0
89421-1
89417-2
89423-3
Offline twk
« Reply #8 on: Mon, 02 February 2015, 00:35:54 »
Nice! Thanks for the pictures!
Offline Data
« Reply #9 on: Mon, 02 February 2015, 14:00:30 »
So are they just painted black or is it something more sophisitcated?  Can you tell?
Offline RSC
« Reply #10 on: Mon, 02 February 2015, 20:12:29 »
It's $19 for 5 keycaps or the whole set? If it's just 5 caps, how do you pick them when you order..?
Offline MrFex
« Reply #11 on: Fri, 06 February 2015, 06:09:02 »
Yes, you pay the specified amount for a 'lot' which contains 5 keys. I simply typed the desired keys I wanted in the description of my order (for two lots) and got a friendly message from the shop owner confirming the selection.
