Author Topic: [WTS] Korean Custom Alu Full Layout 22-108 DG, MX-Mini WKL  (Read 2811 times)
Offline Kaliet
  • Trade Count: (0)
  • Better every day
    • Apollos' Custom Keyboard Gallery
« on: Sun, 04 January 2015, 18:59:54 »
Happy New Year to all of you! ;)
I'm trying to sell these two keyboards I made a while ago.
You cannot see these prices when you personally order them from me. :)
1. 22-108 Dark Gray w/ keycaps - $400
86386-0
- CNCed dark gray aluminum top, midl-ayer, bottom, and bumpon bar
- Krytox-lubed Clear switches with LSD-lubed custom 57g springs, stickered
- White LEDs except on Esc: multi-color, 3 locks: blue, 4 macros above num pad: pink
- Monster Mask's A87EX Ver.1 PCB using the latest ps2avrU firmware
- Easy-to-use GUI client for free keymapping with macros
- TH doubleshot keycaps with Korean and English alphabets(as shown in the photo)
- For more detailed photos: http://22kbd.com/151
2. MX-Mini WKL w/ keycaps - $320
86390-1
- Housing: Aluminum top/middle/bottom for 1800 WKL layout only
                nickel-plated aluminum bumpons,
                acrylic layer between Top and PCB,
                bolted with M3 15mm bolts and nuts for secure conclusion
                Some minor scratches and dents exist but not easily found.
- PCB: ps2avr MX-Mini PCB implanted with ps2avr exension module onboard thus perfectly functioning as a ps2avrU PCB
- Switches: vintage brown switch sliders lubed with Dupont Krytox 103,
                 55g custom spring lubed with LSD oil,
                 Blue switch stickers,
                 Nonclick(tactile) gray slider for spacebar switch (spring is 55g)
- LEDs: ESC and Number Lock(under Pause key) - multi-color LED(changes it's color like rainbow),
            Caps Lock - pink,
            some modifiers - white,
            the rest - blue
- Keycaps: Keylab GB TH Doubleshot with winkey and winkeyless options without numpad keycaps
- Easy-to-use GUI client available for easy programming and macro function
- Carrying bag is not included.
- For more detailed photos: http://22kbd.com/141
« Last Edit: Mon, 05 January 2015, 01:39:15 by Kaliet »
Custom Keyboard Craftsman
