Author Topic: ebay.co.uk: AT clone keyboard, most likely ALPSish  (Read 1511 times)
Offline ed_avis
« on: Mon, 05 January 2015, 11:52:08 »
http://www.ebay.co.uk/itm/111566315215
The FCC id is FMA44HKB6151 which may or may not be Blue ALPS.
Offline jacobolus
Re: ebay.co.uk: AT clone keyboard, most likely ALPSish
« Reply #1 on: Mon, 05 January 2015, 12:46:56 »
With the “Made in Thailand” I’m a bit skeptical. If someone gets this definitely post pics though.
« Reply #2 on: Mon, 05 January 2015, 14:47:35 »
Likely White Alps.
http://deskthority.net/wiki/NTC_KB-6151
Offline RoflCopter4
« Reply #3 on: Wed, 07 January 2015, 00:06:24 »
The keys are the right profile for Alps. If you can get it cheap it might be worth looking at, but otherwise it looks like a cheap, dirty piece of ****.
Acer KB-101A with Blue Alps | HHKB Pro 2 | '85 122 Key IBM Model F | '86 1390131 "Silver Label" Model M | AEK M0115 with Orange Alps | Focus FK-2001 White Alps | Chicony 5181 with SMK "Monterey Blue" Switches | Dell AT101W | Unicomp "Ultra Classic" | Razer Blackwidow 2013
