Author Topic: IBM Wheelwriter Typewriters  (Read 3727 times)
Offline meztek
  • Keyboards! Keyboards everywhere!
« on: Thu, 08 January 2015, 18:19:48 »
While browsing my regular used computer parts stores, I came accross two IBM wheelwriter typewriters: a Wheelwriter 2, and a Wheelwriter 50 Series ii.  Both devices do not function.  One powers on but beeps loudly and does not function, the other does nothing when plugged in.  One is missing a few keys, but other than that the keyboard portion on each typewriter seems intact.  I've no use for them in my typewriter collection even if they were fully functional, but I can get them for $15 a piece.
Does this seem like a good deal?  I have a Model M so I figure I could use the keycaps to deck out my keyboard with some of the cool typewriter keys.  I've also heard the keyboard part of the Wheelwriter is identical to a Model M except it lacks a controller (which can be replaced with an Arduino Teensy, somehow?) and some modern function keys.
Offline jacobolus
Re: IBM Wheelwriter Typewriters
« Reply #1 on: Thu, 08 January 2015, 18:37:23 »
One thing that I think is pretty great is replacing the spacebar and alt keys on a Model F122, 4704 banking terminal board, “space unsaver”, or bolt-modded Model M with the “code” key and spacebar from a wheelwriter. Sacrifices the right Alt key for a left Alt key that is very easy and pleasant to press with a thumb.
Offline fanpeople
« Reply #2 on: Thu, 08 January 2015, 18:41:42 »
Wait, how do you get the code key on the model M and where?
do you mean remove the right alt key and move the space bar over and then put the code key where left alt is? Sorry if obvious and I am just not understanding.
Offline fanpeople
« Reply #3 on: Thu, 08 January 2015, 18:51:04 »
Never mind, answered my own question
86728-0
Offline meztek
« Reply #4 on: Thu, 08 January 2015, 19:00:19 »
That's a good thought, I might consider that but I currently have my right alt mapped to AltGr for typing in Spanish.
@fanpeople, are your coloured keys from Unicomp or elsewhere?  That looks nice.
Offline fanpeople
« Reply #5 on: Thu, 08 January 2015, 19:02:01 »
G'day, cheers
yeah all from Unicomp.
Offline 0100010
  • Not Sure
« Reply #6 on: Thu, 08 January 2015, 19:35:44 »
Ummmm.  I get how that Code key mounts, but not how the spacebar mounts?
Offline jacobolus
« Reply #7 on: Thu, 08 January 2015, 19:40:53 »
The spacebar is 7.25u and has its stems offset, i.e. it’s explicitly designed to fit on the barrels from a standard spacebar and right alt key.
The one slight thing that needs help is the spacebar stabilizer, but wcass’s washer method should work pretty well.
« Reply #8 on: Thu, 08 January 2015, 19:41:48 »
The code key takes the place of L ALT and also uses the left stabilizer hole of the spacebar. The WW spacebar is "moved over" and takes the spacebar hole with the spring in it and the R ALT hole for stabilization. Bolt mod not required however the spacebar stab wire did not line up properly with the clips so one will have to be added.
I found this out a while ago and was going to shock the community but instead I got busy and just told interested people about it. I'm sure others figured it out as well.
Anyway @OP: $15 is a great deal. I still regret not getting more for that price when I had the chance. If you don't want, I'll gladly buy the KBs from the broken ones at that price.
Offline jacobolus
« Reply #9 on: Thu, 08 January 2015, 19:43:21 »
Ah, I guess the useless right Alt spring just sits there and doesn’t get in the way. I was thinking it should be removed.
Offline 0100010
  • Not Sure
« Reply #10 on: Thu, 08 January 2015, 19:56:10 »
Ahhh........
I was thinking the Model M spacebar.  I pulled out one of my wheelwriter key sets, and I see you have to use the wheelwriter spacebar.
Offline meztek
« Reply #11 on: Thu, 08 January 2015, 20:34:07 »
It sounds like some of you have Wheelwriters.  Do you use them for anything in particular, or just a desk piece?
I think at this point I'm trying to justify buying things just because I like the keyboard even though I can't use them in their current state.
« Reply #12 on: Fri, 09 January 2015, 00:51:55 »
Remove with chopstick.
I type notes on mine all the time. It's lighter than the selectric and has spell-check!
Sethstorm turned a WW KB into a DIY 75% model M. I have a few extra KBs that I was thinking of doing that with.
here's the one I bolt modded and use on the typewriter. https://www.flickr.com/photos/dork_vader/sets/72157649783456209/
Offline berserkfan
« Reply #13 on: Fri, 09 January 2015, 01:29:04 »
Ah, too bad it isn't Model F. That membrane thing isn't so nice.
I am still daydreaming about getting my split matrix Model F.
