Author Topic: Wooden wrist rests  (Read 3821 times)
Offline skiwithpete
Wooden wrist rests
« on: Thu, 08 January 2015, 21:13:41 »
Hey guys,
After I hit my 2 month membership and my posts requirement I intent to sell a couple of wooden wrist rests here on geekhack.
Here's some pics of the stuff I've made recently -
Here's just the pics, no prices or sizes.
All together:  http://i.imgur.com/OPS9O9q.jpg
A side profile: http://i.imgur.com/AUnfJo5.jpg
B side profile: http://i.imgur.com/pyulYmX.jpg
C side profile: http://i.imgur.com/K7OrMUL.jpg
Bottom sides: http://i.imgur.com/ahRRozQ.jpg
With vinyl feet: http://i.imgur.com/hfYx1p7.jpg
B notes - slight burning: http://i.imgur.com/hQJEyna.jpg
C notes - scarring: http://i.imgur.com/5doSfHr.jpg
If you're interested in such things - what type of mech you have and what shape of wooden wrist rest interests you.
This sort of info will help me make them for the community.
Thanks,
P
Co-Founder of 1upkeyboards.com
QFR Brown + PokerII Clear
Offline jacobolus
Re: Wooden wrist rests
« Reply #1 on: Thu, 08 January 2015, 23:48:07 »
You might want to put this in “making stuff together” or “keyboards” instead of “ergonomics”. Also, you might want to embed images directly in your post, like:
Anyway, I’m not looking for a palmrest, but these look great. :)
Offline hoggy
  • * Ergonomics Moderator
« Reply #2 on: Fri, 09 January 2015, 00:28:26 »
As Jacobolus has suggested, I've moved the thread.  Hope you don't mind, besides I think you'll get a better reception here.
Offline skiwithpete
« Reply #3 on: Fri, 09 January 2015, 09:12:19 »
Thanks for your help guys.  Appreciate the image advice as well as the forum move.
Cheers,
P
Offline jacobolus
« Reply #4 on: Fri, 09 January 2015, 17:41:55 »
By the way, have you seen The_Beast’s stuff? https://geekhack.org/index.php?board=127.0
You might find some ideas there.
Offline skiwithpete
« Reply #5 on: Fri, 09 January 2015, 18:27:38 »
By the way, have you seen The_Beast�s stuff? https://geekhack.org/index.php?board=127.0
I have seen his stuff, and it is very very very good.  As his were all sold out that I thought it would be ok to post my own.
I should probably contact him to make sure I'm not stepping on his toes.
P
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #6 on: Fri, 09 January 2015, 21:05:07 »
If you want to sell them right now, you can make a webstore on bigcartel.
Offline skiwithpete
« Reply #7 on: Sat, 10 January 2015, 08:22:00 »
I post my stuff over on reddit at the mechmarket - while I intend to make geekhack my permanent home.
Thanks for your suggestion though!  And, btw, ergodox clear?  I'm super jelly of that!
P
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #8 on: Sat, 10 January 2015, 08:35:17 »
P
Yeah, I bought it with clears, and you can open the switches still from the top even though they are plate mount, so I just swapped springs.
