Author Topic: Frankenswitches 'MX Compatible'  (Read 2359 times)
« on: Fri, 09 January 2015, 09:17:54 »
Has anyone tried putting cherry mx stems and springs in kailh switch bodies?
Offline FrostyToast
  • Litshoard
Re: Frankenswitches 'MX Compatible'
« Reply #1 on: Fri, 09 January 2015, 09:46:57 »
Why would you want Kailh bodies?
Quote from: elton5354
« Reply #2 on: Fri, 09 January 2015, 09:57:30 »
Well I was thinking if I've already got cherry stems and springs from an old board where the leaf springs are bad and I've got ~$0.25 kailh switches I could combine the two.
Offline heedpantsnow
  • Old enough to know better
« Reply #3 on: Fri, 09 January 2015, 10:22:42 »
Discovery requires experimentation. Let us know how it turns out!
I'm back.
Offline vvp
« Reply #4 on: Fri, 09 January 2015, 12:36:53 »
... I've got ~$0.25 kailh switches ...
Do you know where to buy them?
« Reply #5 on: Fri, 09 January 2015, 12:42:39 »
Not sure if these are kailh but I know you can get red and brown mx compatible for $0.30 here http://techkeys.us/collections/accessories/products/keyboard-switches
And I should have said IF I can get $0.25 kailh switches as I do not have them currently.
Offline vvp
« Reply #6 on: Fri, 09 January 2015, 14:03:19 »
Thanks, it is still significantly cheaper than e.g. mouser. If you find even the lower price then please post.
