Author Topic: Help me restore this Focus FK-2001  (Read 3238 times)
Offline Geroximo
« on: Fri, 09 January 2015, 15:27:33 »
Hey,
I'm having this sweet little Focus FK-2001 (german version aka FK-2002) right in front of me. I think it has complicated white ALPS, but im unsure.
There's just one little problem. It doesn't work  :'(
When it's plugged in, all LEDs (CapsLock, NumLock and ScrollLock) are on permanently and it does not register anything.
I'm going to open it up and take a look inside. Does anybody know what the problem with this thing could be?
edit: I'll give the switches a good clean and lube them if I can get it running again
« Last Edit: Fri, 09 January 2015, 15:31:05 by Geroximo »
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: Help me restore this Focus FK-2001
« Reply #1 on: Fri, 09 January 2015, 15:41:33 »
Does the logo lift up to reveal DIP switches? It might still be old enough to be XT/AT switchable, and Focus hid the DIP switches under the badge.
Incidentally, those switches … fascinating. Unbranded scrawly switches. I've never seen that variant before — the scrawly switches I've seen have always been branded. What's the date code on the controller chip?
(There are a number of strange variants of white Alps switches that I assume came from factories outside of Japan.)
Bore Awards
Offline Touch_It
« Reply #2 on: Fri, 09 January 2015, 15:44:40 »
A shot in the dark, but maybe it has a bad capacitor somewhere?  I know nothing about this keyboard in particular, but just an educated guess based on the symptoms.  Also, does this have a ps/2 end on it, and are you using an adapter?  Could be the culprit here as well.
Offline Geroximo
« Reply #3 on: Fri, 09 January 2015, 16:31:08 »
Controller Chip:
Date in the housing 10/1990
It also has an AT/XT switch, set on AT. I'm using a 5-pol DIN to PS/2 adapter.
I cannot see any obvious damage on connectors or resistors. Maybe reheating the soldering points helps?
NOTE: LEDs are off initially, but lighten up as soon as you press a key.
Offline Nover
« Reply #4 on: Fri, 09 January 2015, 16:43:40 »
http://circuit-board.de/forum/index.php/Thread/15776-Mechanische-Tastatur-reparieren/
Quite sure that's the one you bought on ebay one or two weeks ago. Maybe it helps to see what kinda attempts have already been made. It's one nice keyboard, so GL!
SSK, Ducky YOTD
  • RIP
    • Boring twaddle
« Reply #5 on: Fri, 09 January 2015, 16:45:59 »
You're connecting it to your PC via PS/2 with the PC switched off, or are you using a PS/2 to USB converter? If the latter, which one?
Bore Awards
Offline Geroximo
« Reply #6 on: Fri, 09 January 2015, 17:02:51 »
it is.
via PS/2 with the PC switched off.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #7 on: Fri, 09 January 2015, 23:58:09 »
Did you clean the contacts between the controller and the keyboard?  You are saying it is lighting up.  Maybe that's it.
  • RIP
    • Boring twaddle
« Reply #8 on: Sun, 11 January 2015, 07:11:30 »
Hm, unless the cable's damaged, it's starting to look like component failure on the PCB.
Bore Awards
Offline Geroximo
« Reply #9 on: Wed, 28 January 2015, 10:59:44 »
Update:
I'm planning to use the switches on a custom board.
Thx for your input.
