Author Topic: Hello  (Read 2037 times)
Offline Ciemnika
Hello
« on: Sat, 10 January 2015, 19:38:34 »
« Last Edit: Mon, 06 October 2025, 12:44:21 by Ciemnika »
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
Re: Hello
« Reply #1 on: Sat, 10 January 2015, 20:53:46 »
Welcome to GH!
Do you still have your model M now? Also I'm not sure if they're in stock but MechanicalKeyboards.com has aluminum cases for the Filco.
GON NerD TKL DTA Edition
Re: Hello
« Reply #2 on: Sat, 10 January 2015, 22:58:15 »
Welcome to Geekhack!
What switches in your Filco?
Aluminium cases for Filco are around, although most places seem to be out of stock.  Quality varies, so be sure to search GH if you find one to see what other think of that particular case.
For example:
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=280
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=212
Offline hoggy
  • * Ergonomics Moderator
Re: Hello
« Reply #3 on: Sun, 11 January 2015, 02:47:26 »
I liked the bit about the 'current' goal... You're amongst friends.
Offline Ciemnika
Re: Hello
« Reply #4 on: Fri, 16 January 2015, 20:03:17 »
« Last Edit: Mon, 06 October 2025, 12:44:17 by Ciemnika »
Re: Hello
« Reply #5 on: Fri, 16 January 2015, 21:47:23 »
@rowdy - They're browns. I'd probably have gotten clears, but I'm impatient, and the browns are cool. I've used blues extensively in the past, too, but they're just too noisy for me. I've seen a number of the cases around, but all are out of stock. As I said, patience isn't my strong suite.
When something you seek is rare, or too expensive, patience is the key.
Some people manage to be in the right place at the right time.  Every single time!  Grrr ...
Otherwise just hang on - there's lots to explore in the keyboard world.
