Author Topic: Can't seem to compile my firmware  (Read 2774 times)
Offline ROFLmonstar
« on: Sun, 11 January 2015, 07:10:02 »
I'm making a custom numpad and I can't seem to compile my edited GH60 firmware using this guide:
http://deskthority.net/workshop-f7/how-to-build-your-very-own-keyboard-firmware-t7177.html
I've edited everything right, compared with the original, but I still get an error with cygwin64 on Windows 8.1. I can however compile the original Makefile.
Here's a pastebin link with all the info: (The parts I changed, and the error from the compiler.)
http://pastebin.com/2zUs1F53
Sidenote: On line 119, it has an error with 'ESC' being undefined. I fixed it by putting 'KC_ESCAPE', instead, but the same errors appears besides that.
Basically I have the same problem this guy had:
https://geekhack.org/index.php?topic=63467.0
And he fixed it by building it on Linux. I'll look for my old Arch VM, and I'll report back.
I also attached a .rar of the entire library if you want to try for yourself or look a bit deeper.
Thanks for your time. If any other information is needed, please ask.
Edit: Got my Arch VM running, still the same error(s) when trying to build the Makefile...
« Last Edit: Sun, 11 January 2015, 08:06:08 by ROFLmonstar »
Offline abjr
    • abjr.org
Re: Can't seem to compile my firmware
« Reply #1 on: Sun, 11 January 2015, 08:37:03 »
Fix your keymap_common.h. You had an extraneous comma and KEYMAP
Code: [Select]
#define KEYMAP( \
    K00, K01, K02, K03, \
    K10, K11, K12, \
    K20, K21, K22, K23, \
    K30, K31, K32, \
    K40, K41, K42 \
    { KC_##K00, KC_##K01, KC_##K02, KC_##K03 }, \
    { KC_##K10, KC_##K11, KC_##K12, KC_NO}, \
    { KC_##K20, KC_##K21, KC_##K22, KC_##K23 }, \
    { KC_##K30, KC_##K31, KC_##K32, KC_NO }, \
    { KC_##K40, KC_NO, KC_##K41, KC_##K42}  \
Also fix your keymap_poker.c. You don't need the leading "KC_". KEYMAP is a macro that expands, so if you put KC_ESC you really wind up with KC_KC_ESC which is not a valid keycode.
Code: [Select]
const uint8_t PROGMEM keymaps[][MATRIX_ROWS][MATRIX_COLS] = {
                   KEYMAP(ESC,KP_SLASH,KP_ASTERISK,KP_MINUS, \
                   KP_7,KP_8,KP_9, \
                   KP_4,KP_5,KP_6,KP_PLUS, \
                   KP_1,KP_2,KP_3, \
                   KP_ENTER,KP_DOT,KP_0)
After I made these changes it compiled fine for me.
-abjr
« Last Edit: Sun, 11 January 2015, 08:40:10 by abjr »
CM QFR | magicforce 68 (Gateron) | magicforce 68 (Outemu) | Acros 6311-K
Offline ROFLmonstar
« Reply #2 on: Sun, 11 January 2015, 08:49:28 »
I forgot to remove the 'KEYMAP' before the array before uploading, it was just something I messed with to make it work.
About the comma and the KC_ prefixes, that was it.
It said that 'ESC', 'SLASH' and everything else was not defined, so I went straight to the KC_ESCAPE and everything else, probably was a mistake.
Thank you very much for your help. Now only flipping the bottom row because I somehow screwed that up, too.
Offline abjr
    • abjr.org
« Reply #3 on: Sun, 11 January 2015, 22:34:57 »
No problem :) Good luck with your project!
