Author Topic: Need Help Designing Keycap  (Read 2511 times)
Offline Firebolt1914
  • POM Overlord
« on: Sun, 11 January 2015, 10:24:11 »
Hey guys, I currently have an idea that I want to make a reality, and I have no clue where to start. I've had the idea of glass keycaps, which have been thought of before, but usually never done. What I found to be the main failing point is the stem, which I've made a solution for: having a hole in the keycap for a plastic stem. The only problem is, I have no idea how I'm going to make a mold for that. If anyone has any pointers or tips, please post them here; I would really love to be able to make glass keycaps.
Offline Dihedral
  • Mostly Harmless
Re: Need Help Designing Keycap
« Reply #1 on: Sun, 11 January 2015, 11:58:49 »
You're going to mould your own glass, or what?
  • POM Overlord
« Reply #2 on: Sun, 11 January 2015, 12:05:54 »
I'm most likely going to cast glass, and I need a mold for that. The problem with that is, is that the stem is really fragile if made out of glass.
Therefore I will need to have a hole where the stem usually is, and put a plastic stem there.
I have no clue how I'm going to make a mold for a keycap with a hole instead of a stem.
« Reply #3 on: Sun, 11 January 2015, 12:11:06 »
There was a thread about this earlier but the guy never made the caps afaik. I'm so excited to see these if you follow through. Good luck!
  • POM Overlord
« Reply #4 on: Sun, 11 January 2015, 12:19:45 »
iirc it was noisyturtle, and he said it didn't work out so well because it exploded :P
  • POM Overlord
« Reply #5 on: Sun, 11 January 2015, 12:27:42 »
Here's a picture of what I'm thinking of: http://imgur.com/adi27MM
Offline lolkey
« Reply #6 on: Sun, 11 January 2015, 14:10:47 »
Buy small little squares of glass and use hand glass cutting tools?
filco ninja mj2 tkl · mx brown · black case · blank black pbt
varmilo va87mr tkl · gateron red · black case · dye sub pbt ❤
vortex pok3r rgb · mx silent · white case · blank xda pbt
Offline Data
« Reply #7 on: Mon, 12 January 2015, 00:00:59 »
Neat.
Sounds like you need 2 molds: 1 for the glass "cap" and 1 for the plastic stem insert.
Also, it seems rubber o-rings might be highly suggested for use with glass key caps.  Nobody wants to shatter his key caps (and fingers!) from bottoming out too hard on a keystroke.   :p
  • POM Overlord
« Reply #8 on: Mon, 12 January 2015, 16:09:08 »
Alright this thread is pretty much useless, secret plans are being formulated, thanks for the help guys :)
Offline pro_LAPSE
  • However, rays of nuclear!
« Reply #9 on: Tue, 13 January 2015, 00:29:53 »
I would say make the stems in a way that they snap into the glass part, and that they cant be rotated at all. Those are the first issues I see. Also, make sure the stems are not too long or short. Perhaps make the plastic stem and a base insert for the bottom as well, so when the key is bottomed out, it wont be glass on plastic, I dont think that would sound too pleasant. Or, you could use permanent o-rings, and make the stem a little longer?
I dont know what you wanted out of this thread, so I am giving you as much advice as I can :D
chopstick cruelty bleeds Aritzia creme.
