Author Topic: Does anyone know how to convert this?  (Read 2272 times)
Offline FrostyToast
  • Litshoard
« on: Sun, 11 January 2015, 19:31:42 »
I have a blue alps keyboard and I would like to convert it to usb or ps/2.
Quote from: elton5354
Offline jacobolus
Re: Does anyone know how to convert this?
« Reply #1 on: Sun, 11 January 2015, 19:34:35 »
What connector is at the other end of the plug originally attached there? That picture just shows a totally generic connector, without any surrounding context that might give us a clue.
It’s probably XT or AT protocol, but it also might be some kind of terminal board, or who knows what.
Offline FrostyToast
  • Litshoard
« Reply #2 on: Sun, 11 January 2015, 19:40:13 »
Sorry, I should have included that.
« Reply #3 on: Sun, 11 January 2015, 19:45:47 »
If that is AT, you can just use an AT to PS/2 adaptor - they use the same protocol.
Then you can use a PS/2 to USB adaptor.
But if it is XT, or something else, you will need a convertor.
« Reply #4 on: Mon, 12 January 2015, 11:04:32 »
There way be a switch on the back or internally to convert it to AT or XT. Look at the PCB and back of the case.
If not, hook it up to soarer's adapter. IT can convert either (though AT to USB converters are plentiful commercially) and has a number of useful features.
Offline FrostyToast
  • Litshoard
« Reply #5 on: Mon, 12 January 2015, 18:42:08 »
Wait, is that what that switch on the back was for?
This is great! Thanks!  ;D
