Author Topic: B-Series online site open  (Read 9855 times)
Offline hojin.yi
    • Winkeyless
« on: Sun, 11 January 2015, 20:05:20 »
B-Series is a group name of PCB produced by Hyodong.Min(nicknamed "beastmask").
Recently he opened new web site to introduce them internationally.
I want to know your opinion on B-serices if you know this products already.
86980-0
[Photo Keyboard using B.87 PCB]
86975-1
[Photo: keyboard using B.87 PCB -2]
86979-2
[Photo : Keyboard using B.pad PCB]
86977-3
[Photo : Keyboard using B.mini PCB]
86978-4
86975-5
[Photo : Keyboard using B.87 EX PCB]
One of the most noticible features of B-series PCB is the ability to freely change the color of RGB LED.
Additionally you can set the keyboard functions as you wish by using “bootMapper Client” program for PC.
New firmware “ps2avrGB” is the upgraded version of ps2avrU with the power to control RGB LED.
And also you can customize and order the acrylic case easily.
PCB Specifications
Layout(Common)
winkeyed/winkeyless combo
Supporting Caps Lock 3000/8000
Supporting Masestouch Space Bar
Supporting 1.75 right-shift
ISO/ANSI
2. Layout(B.87 EX)
Can separate TenKey
Able to switch between 2X TenKey and 1X*2 TenKey
3. Supports RGB LED
pink/white/green/orange/blue/yellow/red
4. Supports Full LED
5. PCB : 1.6T
6. All the parts placed at the back side of PCB
7. Supporting Mount hole for case and plate
8. Mac OS Compatible
Firmware
1.ps2avrGB
All the features of ps2avrU
Can control RGB LED
Easy Key Mapping
Can register macro
2. ps2avrU
Interface : USB /PS2 combo
NKRO & 6KRO Support
Supporting key map for 4-layer.
Supporting all the multimedia keys.
Supporting all special keys
Supporting macro and key mapping
Mac OS Compatible
Size
1. B.87
- Tenkeyless size
2. B.87 EX
- Full Size
3. B.pad
- TenKey size
4. B.face
- 60% of Poker size
- Compatible with poker-x PCB
5. B.thumb
- 60% of Poker size
- micro USB connector
- PCB Thickness : 1.0T
6. B.mini
- MX-mini size
7. B.mini EX
- MX-mini size + tenkey
RGB bar
- Can add RGB Effect of the back side of the keyboard
- Delivered in one-line, not separated as you order.
- White.
- Recommended Length according to PCB
B.87 EX : 12
B.87 : 10
B.mini EX : 11
B.mini : 9 (PCB has 8, but 9 is better due to different space)
B.face : 8
B.thumb : 8
B.pad : 2
* Link : http://winkeyless.kr/en/
Re: B-Series online site open
« Reply #1 on: Sun, 11 January 2015, 20:09:13 »
Really liking the b.mini.
Offline MGH
« Reply #2 on: Sun, 11 January 2015, 20:32:21 »
What is difference between R and EX?
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #3 on: Sun, 11 January 2015, 20:34:55 »
I would have gotten a B 87 had i not ordered another board before hand. Heck i'm still interested right now....
GON NerD TKL DTA Edition
Offline zennasyndroxx
  • It's good to be back!
« Reply #4 on: Sun, 11 January 2015, 21:30:25 »
R is reversed on switch LED position from the usual bottom to the top.
EX is extended. Bmini EX would give you a Bmini with a numpad while B87 EX would give you a full layout
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #5 on: Sun, 11 January 2015, 21:48:54 »
Interesting B pad if it have "000" function :)
Offline FrostyToast
  • Litshoard
« Reply #6 on: Sun, 11 January 2015, 22:01:18 »
Aren't these programmable? I don't know much about B series boards, although I would expect customs to allow that.
Quote from: elton5354
  • Frenzy Classic.
« Reply #7 on: Sun, 11 January 2015, 22:06:09 »
I don't know more about B pad. But I studied about some custom keypad via software keymap like KMAC, Aikon, O2D. It 's seem impossible :( Only hope found Cherry MX keypad can do that :)
Offline byker
  • Literally Canada
« Reply #8 on: Sun, 11 January 2015, 22:16:27 »
Nice site, lots of cool keyboards!  :)
Offline hojin.yi
    • Winkeyless
« Reply #9 on: Sun, 11 January 2015, 22:40:22 »
Hi.
Thanks for your interests.
Model with "R" means the switch LED is placed on top of the key instead of at bottom.
"EX" board has the "num key" like full sized keyboard.(Look at the pictures I attached above.)
Thanks.
« Last Edit: Sun, 11 January 2015, 22:46:08 by hojin.yi »
Offline hojin.yi
    • Winkeyless
« Reply #10 on: Sun, 11 January 2015, 22:45:22 »
B-series is supporting custom macro settings.
So it's possible to set "000 functions" by customizing.
I'll translate the manual in English as soon as possible, and post it.
Thanks
« Reply #11 on: Sun, 11 January 2015, 22:48:05 »
I guess you can set a macro string of 000 and set the key to that macro.
Offline Coreda
« Reply #12 on: Sun, 11 January 2015, 23:03:37 »
Wish there was a list of all the parts on the site required for each assembly. It seems you'd need to purchase the PCB and acrylic case but it's not clear how many LEDs, diodes, etc is needed for each keyboard.
Edit: misread. Seems the diodes and registers are included, and can be ordered to come pre-soldered.
« Last Edit: Sun, 11 January 2015, 23:05:59 by Coreda »
  • Frenzy Classic.
« Reply #13 on: Sun, 11 January 2015, 23:57:49 »
I seems never macro, only think to keymapping. If so, any custom keypad have macro can type "000". I 'll try that in the future :)
@hojin.yi: waiting English manual from you :)
« Reply #14 on: Mon, 12 January 2015, 00:09:59 »
check the screencapture of the bootmapper.
You can set custom macro with delays and stuff and save it under CstMac1 or anything until 12. Then when you're on the keymapper, you can remap the CstMac1 key (if you save the '000' macro to CstMac1) to anywhere you want on the pad.
Hope this helps
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #15 on: Mon, 12 January 2015, 00:10:43 »
So tempted by the mini...damn it.
  • Frenzy Classic.
« Reply #16 on: Mon, 12 January 2015, 00:25:16 »
Hope this helps
Yeah I completely understand. I think I can do it. Thanks for your instruction :)
Offline GL1TCH3D
« Reply #17 on: Mon, 12 January 2015, 08:46:43 »
Where do you get the cases made for your keyboards?
Offline hojin.yi
    • Winkeyless
« Reply #18 on: Mon, 12 January 2015, 22:39:12 »
Hi.
Drawing design is by ourselves.
Cutting is by an acrylic factory in Korea.
(you can search them in the internet.)
Thanks.
Offline intelli78
« Reply #19 on: Mon, 12 January 2015, 22:43:46 »
Do the TKL PCBs fit in a Filco case?
« Reply #20 on: Mon, 12 January 2015, 23:14:19 »
at least not the top part of the case since korean customs' f-row is closer to the numrow compared to costars or oem
Offline berserkfan
« Reply #21 on: Mon, 12 January 2015, 23:29:11 »
looks like everything is going to be custom, thus increasing the cost again.
