Author Topic: Getting into a CM Switch tester  (Read 1882 times)
Offline skiwithpete
« on: Sun, 11 January 2015, 20:24:36 »
Hey guys,
I got a CM Switch Tester and I want to make it into a custom 6 switch keyboard (my first DIY).
But I can't seem to get into the case...
Anyone have a strategy they can share?
I just can't figure out which side the lip is on or how to release it.
Co-Founder of 1upkeyboards.com
QFR Brown + PokerII Clear
Offline skiwithpete
Re: Getting into a CM Switch tester
« Reply #1 on: Sun, 11 January 2015, 21:17:49 »
I figured it out.  You gotta aim for the 1/4 way-in marks on the front and back panels.  Trying to do it in the middle just won't yield any results.
« Reply #2 on: Sun, 11 January 2015, 21:32:08 »
There are at least two threads on here where people put a teensy in these, they might be helpful to you.
I'd link you but I'm on my phone.
Offline Grendel
« Reply #3 on: Sun, 11 January 2015, 21:48:51 »
- I'm game !
