Author Topic: Cherry MX Green vs Clear ?  (Read 18142 times)
Offline dalakada
« on: Mon, 12 January 2015, 00:02:08 »
Hi guys,
I am about to purchase a code keyboard which is so popular I see these days.
And I am about to make a decision abot switch between mx green and clear.
I want to know your ideas, and here is my profile :
I like  tactile feedback, I dont like clicky noise, because I live in a dorm with my roommate.
Thank you so much.
« Last Edit: Mon, 12 January 2015, 00:06:41 by dalakada »
Offline smknjoe
Re: Cherry MX Green vs Clear ?
« Reply #1 on: Mon, 12 January 2015, 00:09:33 »
Clear then.
Personally, I prefer the Greens. As with Blues, you get a little more tactile feedback from the 2 piece stem/slider. However, you also get more noise.
SSKs for everyone!
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #2 on: Mon, 12 January 2015, 00:11:53 »
Hi guys,
Thank you so much.
Clear is perfect for your needs.
« Reply #3 on: Mon, 12 January 2015, 00:12:22 »
55g topre
Offline dalakada
« Reply #4 on: Mon, 12 January 2015, 00:40:42 »
Hi guys again, thanks for the replies BTW.
I researched a lot and I found greens tactile feedback is way better than clears, so do you think it is better idea to concede the tactile feedback greatness for not having clicky sound so chhosing Clear rather than Green.
Anddoes the tactile feedback really differ between Green and Clear too much ?
Offline awts
« Reply #5 on: Mon, 12 January 2015, 00:48:51 »
How about getting a HHKB instead?  :'(
Offline Oobly
« Reply #6 on: Mon, 12 January 2015, 01:40:35 »
Yes, there is a difference in the tactile feedback between Greens and Clears, Clears are MORE tactile, by a large degree actually. Too many people are feeling with their ears, mistaking the audible click for tactile feedback. The tactile bump is the same as on Brown stems and presents the same tactile resistance, but there's actually even less of a drop in force after the bump than there is on Browns (about16cN vs about 12cN), let alone Clears. Look at the force diagrams if you don't believe me. For those who still disagree, try using some good isolating in-ear headphones with music playing and see how tactile your Greens feel then.
If you want tactile, get Clears. If you want clicky, get Buckling springs or clicky Alps. Better tactility AND better sounding click.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Sencha
  • HHKB Pro
  • MX Reds <3
« Reply #7 on: Mon, 12 January 2015, 08:10:43 »
Offline Defect
« Reply #8 on: Mon, 12 January 2015, 08:12:24 »
As Oobly stated (with great photo), clears are more tactile than Greens.  And quieter, too.
Greens use a two part stem to emulate a click within the linear design of Cherry MX.  This leads to negative effects such as Hysteresis
Offline yomammary
« Reply #9 on: Mon, 12 January 2015, 08:21:49 »
Sounds like your first mechanical keyboard. A code with MX clear is perfect for you.
Then you can get into Topre switches ($$$).
RF 87u 55g | Leeku 1800
Offline dalakada
« Reply #10 on: Mon, 12 January 2015, 19:47:35 »
Thank you so much guys, all the comments were really helpful.
I decided to go with Code Mx Clear.
Thank you sooo much again.
« Reply #11 on: Mon, 12 January 2015, 19:49:49 »
I always thought that greens were too heavy for my liking. Stock clears much less so. They're quite nice.
Offline Huxley2500
« Reply #12 on: Mon, 12 January 2015, 20:06:38 »
Green all the way.
Screw roommates.
Offline Lunatique
  • Writer, Composer, Artist, Photographer, Gamer
« Reply #13 on: Tue, 13 January 2015, 03:25:13 »
I find Matias quiet switch the most tactile, non-noisy switch-- more than any Cherry MX or Topre.
Offline smknjoe
« Reply #14 on: Tue, 13 January 2015, 04:23:24 »
Some people get hung up on a single component, such as the size of the "bump", on the overall switch assembly when considering tactility; or hung up on force charts. The greens have the slider which not only adds noise but adds tactile feedback as well. Force charts don't take vibration into account. Think about how much your phone vibrates (if you have the feature enabled) when you type on it. A force chart and the devices used to measure the force can't measure the vibration of your phone which many would agree is more noticeable than the resistance you get from the screen of your phone.
Now, whether greens or any other switches are more tactile than one or the other is really up to the user to decide since force charts only take resistance into account and nothing else. Personally, I have used greens and clears and clears feel like a "heavier" brown and greens feel like a "heavier" blue. I feel I get more tactile feedback from the additional movement in the blues and greens than any other Cherry switches I've tried.
SSKs for everyone!
Offline pro_LAPSE
  • However, rays of nuclear!
« Reply #15 on: Tue, 13 January 2015, 04:33:44 »
55g topre
I dont think that the O.P. mentioned anything about wanting a rubberdome :/
chopstick cruelty bleeds Aritzia creme.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #16 on: Tue, 13 January 2015, 05:11:55 »
I decided to try Greens when I bought my Leopold FC660M. But I couldn't get used to them as the click and smaller bump didn't give me enough feedback to my liking.
Since someone else wanted the Greens they offered to switch it out with Clears and I have been using it a lot more.
|||My other keyboards :
x
« Reply #17 on: Tue, 13 January 2015, 05:30:27 »
55g topre
Thinking outside the box ;)
Offline pro_LAPSE
« Reply #18 on: Tue, 13 January 2015, 05:38:38 »
55g topre
I want to be thinking in your box...
of candy?
:O
« Reply #19 on: Tue, 13 January 2015, 05:44:03 »
55g topre
of candy?
:O
Sorry, I've eaten it all :p
Offline Oobly
« Reply #20 on: Tue, 13 January 2015, 05:52:43 »
Force diagrams show tactile feedback very well, since tactility is related only to the sense of touch, of forces felt by the fingers, which is precisely what a force diagram is measuring. They can of course also measure vibration, it will show as a wavy line on the chart, since after all it's a directional oscillating change in FORCE. Besides, the "click" of Blue and Green switches does not introduce a change in force (vibration) of any significant strength, it's almost entirely auditory (and the part that isn't is transfered to the switch CASE, not the slider which is isolated from the case by a tensioned spring).
The auditory confirmation of switch activation enhances the perceived tactility by the senses complementing and enhancing each other.
tldr; Clears are more tactile, although some people perceive Greens to me more "tactile" due to the sound confirming the actuation of the switch.
« Reply #21 on: Tue, 13 January 2015, 06:22:10 »
Greens are clicky. You said in the OP you don't like clicky noise so it seems like you should go for Clears.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #22 on: Tue, 13 January 2015, 18:57:27 »
And for that more click w/ silence, put some 62g springs in the clears.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #23 on: Tue, 13 January 2015, 19:01:12 »
Greens are a lot heavier than you think. I love both switches, but you will want clears. I guatantee it.
« Reply #24 on: Tue, 13 January 2015, 20:00:15 »
55g topre
topre is the right answer to all "which keyboard should i get/what switch is best" questions.
besides fc660. we don't talk about that.
Offline yomammary
« Reply #25 on: Wed, 14 January 2015, 07:16:34 »
55g topre
Offline smknjoe
« Reply #26 on: Wed, 14 January 2015, 22:43:09 »
That's your opinion and that's cool, man.
SSKs for everyone!
