Author Topic: Are these ABS or PBT?  (Read 3344 times)
Offline Acerpwns
« on: Mon, 12 January 2015, 07:30:28 »
Offline Flyersfan1
  • Hi!
Re: Are these ABS or PBT?
« Reply #1 on: Mon, 12 January 2015, 07:35:18 »
ABS.  :thumb:
Quote from: Photekq
Offline Acerpwns
« Reply #2 on: Mon, 12 January 2015, 07:36:15 »
ABS.  :thumb:
its the same plastic that CM Storm uses on their keyboards correct?
« Reply #3 on: Mon, 12 January 2015, 07:40:07 »
ABS.  :thumb:
Yes
Offline Acerpwns
« Reply #4 on: Mon, 12 January 2015, 07:41:29 »
Offline Dihedral
  • Mostly Harmless
« Reply #5 on: Mon, 12 January 2015, 12:35:46 »
ABS.  :thumb:
Yes
thanks a ton!
Just note this is probably higher quality ABS than the plastic used on CM Storm boards.
Offline Oobly
« Reply #6 on: Mon, 12 January 2015, 15:48:58 »
ABS.  :thumb:
Yes
thanks a ton!
Should be quite at home on that board, though. They look to be OEM profile and similar manufacture technique to many OEM caps. Ups the average quality a little :)
Buying more keycaps,
it really hacks my wallet,
but I must have them.
