Author Topic: custom soarer's converters on Ebay?  (Read 1642 times)
Offline h2gofast
« on: Mon, 12 January 2015, 08:01:26 »
http://www.ebay.com/itm/NEW-Soarers-Converter-Adapter-for-IBM-Model-F-122-Keyboard-Remapping-Macros-NKR-/271644933588?pt=PCA_Mice_Trackballs&hash=item3f3f4cbdd4
I have no affiliation with this.  Has anyone tried one of these and do they work.  It doesn't look like there's enough room in either end  for a teensy.
Re: custom soarer's converters on Ebay?
« Reply #1 on: Mon, 12 January 2015, 08:05:59 »
He is a fellow geekhacker here is his thread about these https://geekhack.org/index.php?topic=64670.0
And they don't actually have a traditional teensy inside.
Offline ShawnMeg
« Reply #2 on: Mon, 12 January 2015, 08:52:53 »
I use one with my F122, and I haven't had any problems with it.  I've been able to remap keys and create macros with it.  If you contact him directly through the board, it'll be 10% less than the eBay price.
IBM Model F122 X 2 internal Soarer's || IBM Model M122 internal Soarer's || AEK II SKCM Salmon ALPS external adb_usb converter ||  AEK M0115 SKCM Orange ALPS click mod external adb_usb converter || AEK M0115 SKCM Salmon ALPS external adb_usb converter ||
Offline Hzza
« Reply #3 on: Mon, 12 January 2015, 08:55:13 »
Indeed, I have a PS2 one from the same seller that works fine (remaps, FN layers, haven't tried macro's yet but I don't see why they wouldn't work if the other functions works well).
