Author Topic: [UK] Samsung Q1 keyboards x 3  (Read 2867 times)
Offline Rajagra
« on: Mon, 10 August 2009, 13:58:57 »
http://shop.ebay.co.uk/?_from=R40&_trksid=m38&_nkw=Samsung+USB+laptop+keyboard%2Fmouse
This one went for £11.50 + £5 P&P. Maybe these will go for less.
See this, I don't know if the pointer will work without a driver.
Offline lowpoly
« Reply #1 on: Mon, 10 August 2009, 14:49:28 »
The stick works. It is just a bit too hard. If you don't use a mouse you can crank up your mouse settings which will make it softer.
Offline Rajagra
« Reply #2 on: Fri, 21 August 2009, 06:19:20 »
I did buy one of these eventually for £10 all in. The "trackpoint" works OK without drivers (I already had mouse speed set fairly high.) The only thing awkward for me is I was hitting the mouse buttons instead of the space bar. Still, a nice item, you'd be hard pushed to find any other decent keyboard with mousing device at this size. Even comes with a neoprene slip case and a larger rigid case for holding the Q1 device as well as the keyboard (I'm sure I'll find a use for it!)
