Author Topic: how would i remove a white alps switch?  (Read 3222 times)
Offline Shyfe
« on: Mon, 10 August 2009, 14:45:36 »
i want to remove one from one keyboard and put it in another. help please?
HHKB (55g) | IBM SSK | Realforce 87U (55g) | Unicomp EnduraPro | KBT Oni
Offline bigpook
« Reply #1 on: Mon, 10 August 2009, 16:42:24 »
do you know how to use a soldering pencil?
Offline Shyfe
« Reply #2 on: Mon, 10 August 2009, 17:17:32 »
no
Offline bigpook
« Reply #3 on: Mon, 10 August 2009, 17:38:40 »
that could be a problem. You will have to unsolder the switch from the PCB in order to move it. You can get a soldering pencil at radio shack, along with some wire braid.
If you have never soldered before I would suggest not tackling a keyboard first. The reason is that you don't want to overheat the keyswitch, doing so will ruin it. Not sure what I would have you practice on first though.
Offline wellington1869
« Reply #4 on: Mon, 10 August 2009, 18:33:26 »
find someone who has a lot of practice soldering...
using: ms 7000/Das 3
Offline sixty
    • http://deskthority.net
« Reply #5 on: Mon, 10 August 2009, 18:43:31 »
There is this guy on youtube who for some reason seems to be into collecting diapers and wearing them. But that is none of my business to judge, he got a mighty good video on how to do exactly what you asked for:
http://www.youtube.com/watch?v=PLgQvmF3zOk
Offline mmgoose
« Reply #6 on: Mon, 10 August 2009, 20:36:41 »
Customizer Ultimate
Offline rdjack21
« Reply #7 on: Mon, 10 August 2009, 21:44:15 »
For something to learn on go to your local Goodwill or salvation army and buy the cheapest computer that is laying around. Then take it apart and use any of the circuit boards you find in the computer to learn how to solder. For this exercise you really want to concentrate on through hole parts. Surface mount parts can come later. So start removing anything that goes through the board (Headers, Caps) Stick to the little stuff don't wast your time trying to remove one of the expansion slot connectors put you can use the pins to practice on.
NOTE: If you have any old computers laying around use those instead of buying one. Old computers are a great source for learning how to do all kinds of electronics work.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline rdjack21
« Reply #8 on: Mon, 10 August 2009, 23:33:53 »
Quote from: ripster;108789
Just don't pop open any recently used power suppliers and practice on the caps.  ZZZZAP!
Oh man you are ruining all the fun for him... But yea don't play with big caps. I put my arm across on in a AC unit when I was younger and it threw me across the room. Now that was a ZZZZAP!!!!
Keyboards
Black Alps: ABS M1
