Author Topic: Realforce 23U Internals  (Read 7160 times)
« on: Thu, 15 January 2015, 09:44:17 »
I'll add more pictures and do a proper writeup when I put it back together but wanted to share some internal pictures for the curious.
In case the forum pics go down here is an imgur album https://imgur.com/a/QZ3KE
*Can't seem to add pics at the moment will try again later.*  :-\
« Last Edit: Thu, 15 January 2015, 09:56:16 by SpAmRaY »
Re: Realforce 23U Internals
« Reply #1 on: Thu, 15 January 2015, 09:44:26 »
Reserved
« Reply #2 on: Thu, 15 January 2015, 09:57:58 »
One thing I've seen that I find interesting is that the 23U PCB is setup to use all 1x keycaps or have 2 2x unit keys if the manufacturer decided to.
Offline berserkfan
« Reply #3 on: Thu, 15 January 2015, 13:14:13 »
Oho!
Now you're onto Topre now?
« Reply #4 on: Thu, 15 January 2015, 13:17:47 »
All you need is one more dome and spring!
Offline intelli78
« Reply #5 on: Thu, 15 January 2015, 13:20:31 »
Also, I assume the controller needs to actually support it... may not be the case.
« Reply #6 on: Thu, 15 January 2015, 13:21:11 »
They almost always do, if the PCB supports it.
Offline intelli78
« Reply #7 on: Thu, 15 January 2015, 13:24:41 »
Yeah, you are probably right, wouldn't make a lot of sense to design a crippled controller when it's probably a small incremental effort to support the entire PCB. I wonder what code the extra contact sends.
« Reply #8 on: Thu, 15 January 2015, 13:25:03 »
Oho!
For the second time. :D
