Author Topic: too hot out  (Read 15195 times)
Offline wellington1869
too hot out
« on: Tue, 11 August 2009, 10:55:16 »
its ridiculously hot in nyc.
so hot that i'm considering going to the library just for the industrial air conditioning.  My puny window airconditioner just isnt cutting it.
how hot is it? Lets see, at 6am this morning, it was like 80 degrees out. :)
It got worse from there :)
using: ms 7000/Das 3
Offline huha
too hot out
« Reply #1 on: Tue, 11 August 2009, 10:56:27 »
Could you give this in degrees Kelvin, please? We should really adapt to SI units as soon as possible.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
too hot out
« Reply #2 on: Tue, 11 August 2009, 10:56:28 »
so hot that my university's servers crashed cuz apparently the air conditioners in the server room couldnt handle it, they conked out.  So no email for me either :)
too hot out
« Reply #3 on: Tue, 11 August 2009, 10:57:08 »
Quote from: huha;108863
Could you give this in degrees Kelvin, please? We should really adapt to SI units as fast as possible.
-huha
lol.  I believe the Kelvin equivalent is "Damn! Thats Hawt!!!!"
Offline itlnstln
too hot out
« Reply #4 on: Tue, 11 August 2009, 10:59:12 »
It's been over 100 F here for about two months straight.  It's been horrible.  Who said global warming was a bunch of horsesh*t?
Offline rdjack21
too hot out
« Reply #5 on: Tue, 11 August 2009, 11:16:22 »
Quote from: itlnstln;108866
Hey it's Texas it's summer get over it. I would not call it horrible though. If you want horrible go to Houston where you have both the heat and the humidity to deal with (I grew up there) now that is horrible. I really dislike the constant high humidity in Houston that is the main reason I moved to Austin. So now it is dry and Hot much easer to deal with.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
too hot out
« Reply #6 on: Tue, 11 August 2009, 11:18:06 »
Quote from: rdjack21;108871
"its not the heat its the humidity"
Offline itlnstln
too hot out
« Reply #7 on: Tue, 11 August 2009, 11:22:03 »
San Antonio's weather is a little different than Austin's.  We get the Gulf moisture that gets us as humid as Houston and Corpus.  The Hill Country keeps the moisture (and heat) from getting up towards Austin.  Also, this is one of the hottest Summers we have had in several years.  My lawn feels it.  I need to shred it and sell it as hay.
Offline timw4mail
    • https://timshomepage.net
too hot out
« Reply #8 on: Tue, 11 August 2009, 11:42:27 »
Strange, it's still been a rather cool summer in Michigan, hovering around 70-85F, I'd estimate...
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
too hot out
« Reply #9 on: Tue, 11 August 2009, 14:34:14 »
gah i'm in the library now and still dripping sweat. All the nice seats by the ac vents are taken of course.
too hot out
« Reply #10 on: Tue, 11 August 2009, 15:45:42 »
Quote from: ripster;108931
Dang, tell them you're researching old monk scrolls and need access to the special temp controlled room.
:-D
maybe i can pull the fire alarm and clear the place out just so i can sit by the vents for a minute :)
« Last Edit: Tue, 11 August 2009, 16:20:13 by wellington1869 »
Offline itlnstln
too hot out
« Reply #11 on: Tue, 11 August 2009, 15:46:42 »
Quote from: wellington1869;108933
:-D
maybe i can pull the fire alarm and clear the place out for a minute just so i can sit by the vents for a minute :)
Maybe you can set the sprinklers off, too.
Offline JBert
too hot out
« Reply #12 on: Tue, 11 August 2009, 15:50:31 »
Quote from: itlnstln;108934
Will somebody think of the keyboards?!?
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline itlnstln
too hot out
« Reply #13 on: Tue, 11 August 2009, 15:58:05 »
Quote from: JBert;108935
It's a library.  They couldn't be that great.
too hot out
« Reply #14 on: Tue, 11 August 2009, 16:20:58 »
that'll cool the servers down ;)
Offline itlnstln
too hot out
« Reply #15 on: Tue, 11 August 2009, 16:32:47 »
Quote from: webwit;108945
Typical Dutch summer. (I grew up here)
Thanks for the "NSFW" warning.
Good thing I looked at the link's address before I clicked.
Offline rdjack21
too hot out
« Reply #16 on: Tue, 11 August 2009, 16:33:37 »
Quote from: wellington1869;108862
Oh come on man it is only 89 in nyc right now (5:14 EDT) man we would call that a cold front where I'm at. Darn we see those kind of days in the winter around here.
Keyboards
Black Alps: ABS M1
too hot out
« Reply #17 on: Tue, 11 August 2009, 16:35:25 »
Quote from: rdjack21;108947
hahaha but its not the heat its the humidity!  I know if I go outside I'll melt. Like a tuna sandwich.
« Last Edit: Tue, 11 August 2009, 16:38:05 by wellington1869 »
Offline itlnstln
too hot out
« Reply #18 on: Tue, 11 August 2009, 16:35:30 »
I'd take that right now. It's 102 F here.
too hot out
« Reply #19 on: Tue, 11 August 2009, 16:47:17 »
its like a national geographic special ;-D
Offline vils
too hot out
« Reply #20 on: Tue, 11 August 2009, 17:10:11 »
I love dutch summers, or more precisly I loved when my mother took my 3 year old to the Netherlands for a week this summer. My best vacation for .... ehh three years.
It\'s the glass pipe fallacy. You can only believe that if you\'re on crack.
Offline vils
too hot out
« Reply #21 on: Tue, 11 August 2009, 17:36:48 »
My mother I belive had her dutch trips in the 70's but both she and my second born returned without any major drug related affects.... just well fed.
« Last Edit: Tue, 11 August 2009, 17:38:36 by vils »
too hot out
« Reply #22 on: Tue, 11 August 2009, 17:56:33 »
Offline rdjack21
too hot out
« Reply #23 on: Tue, 11 August 2009, 22:24:30 »
I think our hottest day this year was around 107 or 108 don't remember which. So today at only 102 was a nice day out as long as you stayed out of the sun and in the shade. I was out riding my bike today with the kids and it was nice. Just have to make sure and drink plenty of water and you will be OK. Oh just if you are wondering yes it was around 100 when we went riding but we had a little overcast and no direct sun light. If it had been a blue bird (no clouds) we would have waited a bit before going riding but still would have gone.
Keyboards
Black Alps: ABS M1
Offline o2dazone
too hot out
« Reply #24 on: Wed, 12 August 2009, 08:29:13 »
Do we get to complain about the weather where we live? Las Vegas here, over 100f every day! "Dry heat", all the humidity is replaced by an additional 10 degrees lol
too hot out
« Reply #25 on: Wed, 12 August 2009, 11:27:59 »
Quote from: o2dazone;109105
i'd take a dry heat over this ridiculous humidity any day. Its so much easier to handle dry heat!
Offline o2dazone
too hot out
« Reply #26 on: Wed, 12 August 2009, 11:39:00 »
it's purely subjective. I've talked with people from Florida that prefer it to be not as hot, and a little humid. I sweat like a pig in Orlando, my blood was made for Vegas weather.
With that said come move to Vegas, so I can geek out with someone about keyboards :P
too hot out
« Reply #27 on: Wed, 12 August 2009, 11:46:29 »
Quote from: o2dazone;109138
nevada is one of the places my mom is thinking of moving to after she retires. I guess its either nevada or florida ;)  maybe arizona.  No snow to shovel :)
Offline bigpook
too hot out
« Reply #28 on: Wed, 12 August 2009, 12:45:04 »
I would take Phoenix over Tampa, but thats just me. You also need to consider the culture/taxes/people you will be living around. Phoenix wins on this, at least for me.
Offline o2dazone
too hot out
« Reply #29 on: Wed, 12 August 2009, 13:45:43 »
Quote from: ripster;109146
Change girls in elf outfits and Santa Elvis's - not my particular thing.
That just means you're not kinky enough
Offline rdjack21
too hot out
« Reply #30 on: Wed, 12 August 2009, 14:07:30 »
My self I prefer dry heat over humid heat. In dry heat at least sweat works the way it is supposed to. When I lived in Houston we had a saying that went something like this.
"Going out side is like taking a shower except you stink" What is meant by this is as soon as you walk out the door you are covered in sweat that does not evaporate until you walk into the AC.
After going to Florida for vacation I can say I would not like living there. Way to humid but at least it was not as hot as Houston.
Keyboards
Black Alps: ABS M1
too hot out
« Reply #31 on: Wed, 12 August 2009, 15:04:00 »
Quote from: rdjack21;109182
not to mention boa constrictors in your toilet bowl
Offline bigpook
too hot out
« Reply #32 on: Wed, 12 August 2009, 19:06:48 »
Yeah, florida sucks big time for humidity during July,August and September. The winter months are quite nice though. Its cool and dry most of the time. But then again, Phoenix was very nice in the winter time too.
too hot out
« Reply #33 on: Wed, 12 August 2009, 21:01:11 »
Quote from: ripster;109315
I want to lick that chair.
i want to lick laptop girl
too hot out
« Reply #34 on: Wed, 12 August 2009, 21:20:25 »
Quote from: ripster;109317
She disappeared so the chair will have to do.
How come nobody took my ALPs bait about the guy who dresses up his GF in diapers and a bunny suit.  Now THAT still freaks me out.  Are all ALPs lovers like that?
bigpook would know ;)  Isnt that him in the bunny suit?
« Last Edit: Wed, 12 August 2009, 21:35:34 by wellington1869 »
Offline rdjack21
too hot out
« Reply #35 on: Wed, 12 August 2009, 22:46:37 »
Oh I know "the look" well. I get it every time a new keyboard shows up. But I really got when I told her how much she was spending on that keyboard out of Japan for my birthday.
Keyboards
Black Alps: ABS M1
