Author Topic: Pcb with controller for coolermaster switch tester  (Read 3088 times)
Offline Ari Gold
« on: Sun, 18 January 2015, 01:39:58 »
Hey,
Another new member here. Been browsing for a while though!
I recently joined the MD drop for the CM switch tester. And that got me thinking, it seems such a waste of money. I could have gotten plenty of switches for the same amount of money.
So why not make use of it, and handwire a teensy.
But that would total at about $40 for just 6 keys.
So using the teensy just seems way more expensive then needed.
So why not design a small pcb with a basic controller, that still allows nkro, 1 or 2 function layers (resulting in 10 and 12 functioning keys each)
How would I design such a thing, and if it ever gets to being produced, would it be worthwile and not overly expensive?
Regards,
Thomas
Re: Pcb with controller for coolermaster switch tester
« Reply #1 on: Mon, 19 January 2015, 21:33:04 »
« Reply #2 on: Mon, 19 January 2015, 21:37:17 »
« Reply #3 on: Mon, 19 January 2015, 21:42:07 »
You mean like this:
https://geekhack.org/index.php?topic=67338.0
He doesn't want to have to use a teensy.
I mentioned in the topic I linked that you could build something like that with an arduino pro micro for cost savings.
« Reply #4 on: Mon, 19 January 2015, 21:42:27 »
The Techkeys business card uses an ATmega16U2, right? Those are pretty cheap, and would be useful in such a project.
Offline Grendel
« Reply #5 on: Tue, 20 January 2015, 13:58:00 »
Not necessarily -- you still need some external components like an oscillator, resistors, USB connector. IMHO the cheapest (and a lor more easy) way is to use a Pro Micro clone (seen these for ~$6 on eBay.)
Teensy's have a very good reliability record tho, I'll most likely stick to it for more SixShooter boards.
Edit: Also, the U2 chips have only two timers, driving 4 LED's via PWM is already pushing it. The U4 chips allow you to drive 6 LED's w/o problems.
Edit2: Well, except the Pro Micro -- looks like only 5 of the 6 PWM channels are available on the pads :(
« Last Edit: Wed, 21 January 2015, 15:35:43 by Grendel »
- I'm game !
