Author Topic: [Question] Phosphorglow LED mod?  (Read 2723 times)
Offline six_chains
  • Looking for fashion bae.
    • Visual Art
« on: Sun, 18 January 2015, 22:02:29 »
photo credit: phosphorglow
Pin Layout:
What's it take to do this mod w/ a Teensy?
« Last Edit: Sun, 18 January 2015, 22:14:41 by six_chains »
Model M JIS Silver Label  --  Exent  -- Apple IIs ALPS -- Poker II Granite R1
Offline arakula
Re: [Question] Phosphorglow LED mod?
« Reply #1 on: Mon, 19 January 2015, 00:54:40 »
3 LEDs, 3 ~1K resistors. Very thin cables. Soarer's doc has details.
phosphorglow presumably did this mod by gluing the cables to the inside of the barrel plate (seems to be his usual modus operandi), so if you want to stay close to that / do not want visible cables, a bolt mod would be necessary.
[Edit:] Actually, looking at this SSK mod, he might also have used SMD LEDs and routed the cabling from the front side. That would be non-destructive and reversible.
« Last Edit: Mon, 19 January 2015, 01:08:37 by arakula »
Offline six_chains
    • Visual Art
« Reply #2 on: Mon, 19 January 2015, 01:48:33 »
very interesting. the barrel plate technique is genius; perfect space. Sadly I've already bolt modded my M.
That second link looks more viable with the non-destructive wiring, but not sure how it connects to the controller.
Offline arakula
« Reply #3 on: Mon, 19 January 2015, 02:35:05 »
That depends on the firmware. For Soarer's Converter, it's in the documentation enclosed in the .zip file, on the page named hardware.html.
« Reply #4 on: Mon, 19 January 2015, 02:53:56 »
But be aware that there's an error as you need to put +PIN if you're not using the -PIN option option (the documentation leaves the + off so it errors when you compile)
Offline arakula
« Reply #5 on: Mon, 19 January 2015, 04:52:57 »
And what exactly are you referring to here?
