Author Topic: Kana v2 wrongly registering jerks.  (Read 3569 times)
Offline LaugeGregers
« on: Wed, 21 January 2015, 11:44:49 »
I have a problem with my Steelseries Kana v2.
When I do a quick jerk, it will sometimes not register the movement properly. In these cases it will even move a little in a random direction.
It feels like it doesn't update quickly enough, and does a "guess" for where I would have moved my mouse.
The problem occurs on both Windows and Linux, so it is not a problem with operating system, it even occurs outside of any games.
Has anyone else experienced this problem? And is it possible to return the mouse as malfunctioning?
Offline munch
Re: Kana v2 wrongly registering jerks.
« Reply #1 on: Wed, 21 January 2015, 15:39:09 »
hmm. have you tried a different mousepad surface with it?
the sensor should be able to handle a few meters per second speeds, but is quite sensitive to the wrong type of surface.
which one are you currently using it with?
« Reply #2 on: Thu, 22 January 2015, 08:21:42 »
I am currently using a Steelseries qck+, so I would that wouldn't be the problem, though the mousepad is quite old.
Offline munch
« Reply #3 on: Thu, 22 January 2015, 21:36:50 »
oh, no, that should definitely not be it then. there's nothing stuck in the lens / or any scratches on the lens of the sensor?
