Author Topic: Hi All  (Read 2324 times)
Offline Dyaems
Hi All
« on: Wed, 21 January 2015, 19:38:26 »
Hey Geekhack,
Nothing much to say but I am Dyaems, whichs is a misspelled James and I only use those two usernames in forums, but mostly the former since James is a pretty common name.
I only own a HHKB PRO JP since i am used to its layout because my old membrane keyboard is also using that layout. I can use the usual layouts though since I am using a generic keyboard in my office! Oh, I also own a yellow Realforce 108KT as my replacement keycaps.
I might buy a Model M or F sometime but I might have to have the model F modded because I'm terrible at soldering despite I used to fix/recable headphones, which is ironic-ish.
I don't really use english as my primary or secondary language so I apologize for any mistakes!
« Last Edit: Wed, 21 January 2015, 19:41:11 by Dyaems »
   B.face X2
  65g Zealios
Offline DrHubblePhD
  • I am star stuff
Re: Hi All
« Reply #1 on: Wed, 21 January 2015, 19:39:31 »
Welcome to GeekHack! Protect your wallet, it will be hunted by the temptations of purty plastics...
Re: Hi All
« Reply #2 on: Thu, 22 January 2015, 04:27:24 »
Welcome to Geekhack!
Yellow - nice :)
Model M or F would be great - everyone says the F is better, but you can start with an M and just get a SDL to USB cable, or a PS/2 to USB adaptor and just plug and type.
Offline MAR82
  • Keyboard Addict
Re: Hi All
« Reply #3 on: Thu, 22 January 2015, 05:09:22 »
Looks good to me, Welcome to the community!
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
Re: Hi All
« Reply #4 on: Thu, 22 January 2015, 23:02:41 »
Welcome to GH!!!
If you're used to the JP layout, does that mean you're Japanese? or just somewhere that uses ISO?
GON NerD TKL DTA Edition
Offline Dyaems
Re: Hi All
« Reply #5 on: Thu, 22 January 2015, 23:25:58 »
Welcome to GH!!!
No, I'm not Japanese. Its a long story, and its a saaaad one!
Yellow - nice :)
I honestly just want to try one. Same thing I did with my Topre keyboard, and might as well buy an SSK while I'm at it if I were to because I don't use the numpad at all.
I am really leaning towards an F but their non-fullsized (space unsaver?) is rare and really expensive. Not to mention they are needed to be modded, or something? Haven't done a good amount of research yet so I'm not sure.
Thanks! Although I think i will be immune to those, heh. The HHKB and 108KT is more than enough!
Thanks! :cool:
   B.face X2
  65g Zealios
Re: Hi All
« Reply #6 on: Thu, 22 January 2015, 23:44:44 »
Hi!  Sounds like you're off to a great start!  :)  I hope you're able to own a Model M or Model F soon, they are quite nice.  ;)
Enjoy your time here, and watch out for your wallet!  :))  Welcome to geekhack!
Re: Hi All
« Reply #7 on: Wed, 28 January 2015, 03:40:25 »
Yellow - nice :)
An SSK would be an expensive option just to try!
I was lucky and found two full size Model M for just over $30.  A little bit of cleaning, a couple of extra keycaps, and one of them was good to go (the other needs a bolt mod and a few more keycaps).
Now I know I like them, and I'd really like an SSK!
