Author Topic: Mechanical Switch Business Grade Keypad Numeric Pad  (Read 13301 times)
Offline Rajagra
« on: Thu, 13 August 2009, 05:27:12 »
USB Mechanical Switch Business Grade Keypad Numeric Pad
   * 100% Brand New
    * Color may be vary
    * Industrial Grade heavy duty
    * Standard Keypad with Mechanical key-switch
    * Plug and Play
    * No drivers required
    * Interface: USB
    * Operation system: Windows 98SE/2000/XP/ Vista / Windows 7 /linux
    * Life cycles: 50 million keystrokes
    * Key pitch: 19mm
    * Key Travel: 8mm
    * Dimension: 6 X 3.75 X 1.3 inch
    * Weight: 185 ( gm )
    * For heavy duty task such as business accounting, special POS which use keypad
"Key Travel: 8mm" ? XXXNot Cherry MX then.XXX
Might be worth a gamble, they're cheap enough.
EDIT> Glad to see I was wrong about the switches not being Cherries (see below.) Still waiting for mine.
« Last Edit: Mon, 31 August 2009, 16:09:47 by Rajagra »
Offline kyamei
« Reply #1 on: Thu, 13 August 2009, 05:39:32 »
For $15, I just may have to order one.
EDIT:  Ordered one, wonder what's in it.
EDITEDIT: It kind of resembles that Kinesis keypad Ripster reviewed before.
« Last Edit: Thu, 13 August 2009, 05:46:07 by kyamei »
Topre:  Realforce 101, Realforce 87U, HHKB Pro 2
Cherry Brown:  Compaq MX11800
Cherry Blue:  Filco FKBN87MC/EB
Cherry Black:  K-202 numerical keypad
Alps Black:  AT101W, ABS M1
Alps White:  Focus FK-2001
Buckling Springs:  Model M 1391401, Lexmark Model M 82G2383, Model M2
Buckling Sleeves:  Unicomp Model M4
Futaba:  Sejin EAT-1010
Offline wellington1869
« Reply #2 on: Thu, 13 August 2009, 07:46:48 »
Quote from: kyamei;109393
when you get it let us know what switches it has!
using: ms 7000/Das 3
Offline chongyixiong
« Reply #3 on: Mon, 17 August 2009, 12:20:43 »
Please update on what switches are those, seems to be nice and good enough for my Tenkeyless, I do really need some numpads.
Offline kyamei
« Reply #4 on: Tue, 18 August 2009, 03:06:02 »
I'll post some pics/impressions when I get it.  Estimated shipping time is 2-4 weeks, hopefully less since I'm in Hawaii.  Then again, knowing the postal service, they'll ship it the opposite way around the world.
Offline kyamei
« Reply #5 on: Sat, 29 August 2009, 21:07:06 »
Just got delivered today.  Here's some quick impressions/pics.
Model K-202, no brand listed.  Came in a brown box with no paperwork, seems to be an OEM product.  Uses Cherry blacks, which surprisingly don't seem as heavy as people make it out to be.  I'd say its about the same as a Model M.  Double length keys don't seem to have any stabilizers so off-center presses causes them to stick.  Overall, I'd say it was well worth $15.
Offline kyamei
« Reply #6 on: Sat, 29 August 2009, 22:12:23 »
Nope, I don't see any diodes in that hole.
Offline Rajagra
« Reply #7 on: Wed, 02 September 2009, 10:29:59 »
Quote from: ripster;113030
And are you sure there are NO stabilizers - mine had two sliders on either side of the switch but no stabilizing bar.
Nope.
Doesn't seem to harm the action badly, though it is amusing watching the big keys rock if you deliberately push them off-centre.
The big keycaps have 3 connection points, the middle one attaches to the centred switch.
Offline rdjack21
« Reply #8 on: Wed, 02 September 2009, 11:49:48 »
Quote from: ripster;113952
Hey, if nothing else it's a cheap way to try Black Cherry switches.  If I don't like it I may solder in a brown and blue cherry  too and donate it as a "Geekhack testing device".
Thats not a bad Idea. Try them all at one time. See if you can find some whites as well to put on it as well.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline Hofy
  • Voids Warranties
« Reply #9 on: Thu, 03 September 2009, 16:58:15 »
I also have one on the way.  I guess I will have to see how I like it and maybe mod it over to blue Cherry switches.
Poker II Cherry MX Blue
Filco TenKeyless Zero Fukka
Cherry ML4100
IBM Model M 1391401 Buckle Spring Luvin
Offline kyamei
« Reply #10 on: Thu, 03 September 2009, 17:01:56 »
These $15 specials are PCB mounted and my Kinesis is plate mounted.
These are plate mounted, there's just big gaps in the plate on the sides of the switch of the large keys.
Offline Hofy
  • Voids Warranties
« Reply #11 on: Thu, 17 September 2009, 18:41:00 »
Rip, 2 weeks HK to US is actually pretty good.  I have had surface mail make it in 8 days, but my poor brother in law has had to wait over a month sometimes.  I should have mine when I get home on Saturday.
Cherry ML4100
Offline timw4mail
    • https://timshomepage.net
« Reply #12 on: Thu, 17 September 2009, 21:52:59 »
Quote from: ripster;118821
I just got mine.  (sure takes a while from Hong Kong - $4 declared value LOL).
Not a bad keypad at all for $15.  The switches are mounted weird though - instead of a metal plate it's a PCB material and very thin.
Works fine and I can see now why Cherry Blacks could be very good for gaming but suck at typing.  You can buy also buy 10 of them instead of one Topre numpad.  The Topre doesn't go clicky clicky either and you STILL have to pay extra for the Red Esc key.
No excuse you big boat "You'll Pry The Numpad From My Dead, Cold, Accountant Hands" keyboard diehards.  Try it.  $15.  Free but deadly slow shipping.
I'll post some pics.
If I were going to try out linear switches, I would get a whole keyboard, not just a numpad.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
« Reply #13 on: Sat, 19 September 2009, 12:07:06 »
just ordered mine too. Hope it doesnt take a month.
Offline Hofy
  • Voids Warranties
« Reply #14 on: Sat, 19 September 2009, 13:50:15 »
Mine wasn't here today. :-(  Maybe Monday.
Cherry ML4100
« Reply #15 on: Sat, 19 September 2009, 13:57:27 »
Quote from: Hofy;119266
actually in the last second i hesitated about ordering it. I guess i'm still thinking about it. I bought this baby a couple of weeks ago, paid just $10 shipped on ebay:
http://www.amazon.com/IBM-Numeric-Keypad-Thinkpad-USB/dp/B00004Z7F0/ref=sr_1_2?ie=UTF8&s=electronics&qid=1253386534&sr=8-2
Its mushy, tho i like the little mini wrist-rest its got. But its mushy. So I'm thinking about the black cherry one. But then i'm stuck with two numpads, lol. And if I upgrade to the TP3 soon, it'll have a built-in numpad anyway. So most likely i wont need either external numpad really. So I'm hestiating. On the other hand, 15 bucks is pretty cheap for a clicky one. ;)
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #16 on: Tue, 22 September 2009, 05:39:14 »
Ah, this one... I'm pretty sure I know who builds em!
A Ghost From The Past
Offline itlnstln
« Reply #17 on: Tue, 22 September 2009, 07:43:01 »
Quote from: TheSoulhunter;119753
I'll be sure to take advantage of their low labor cost in China.
  • ~ BOOO ~
« Reply #18 on: Tue, 22 September 2009, 09:45:53 »
Btw, had some conversation with them some time ago...
Keypad GL-002:
- MOQ is 200pcs, $16.9 per 1pcs (for OQ of 200pcs)
- Can be made with MX switches in black and blue
Cherry MX keycaps:
- Can be ordered separately
- The MOQ is 10000pcs for single caps
- They offer blank keycaps
- The price for custom caps is $0.082 per 1pcs keycap + tooling costs (once)
- The price for 200 QWERTY sets (stock) is $12.00 per 1set
- The price for 1000 QWERTY sets (stock) is $9.50  per 1set
« Last Edit: Tue, 22 September 2009, 09:55:58 by TheSoulhunter »
Offline itlnstln
« Reply #19 on: Tue, 22 September 2009, 10:26:11 »
Quote from: ripster;119790
They must get ultralow pricing on the switches too (no, these are NOT clone or reject switches). Makes me think there is no reason why so many of these Cherry switch keyboards are over $100.
I agree, and the G80-3000 is well under $100 in many places, so I don't really see why there aren't more low priced Cherry 'boards.
Offline timw4mail
« Reply #20 on: Tue, 22 September 2009, 11:38:46 »
I'd assume the pricing is what the market will bear.
  • ~ BOOO ~
« Reply #21 on: Tue, 22 September 2009, 12:48:37 »
From my correspondence with Costar its seems:
- Full ANSI/QWERTY non NKRO boards with ALPS (like the ABS) cost ~25USD at MOQ
- Full ANSI/QWERTY boards with NKRO and Cherrys (like the Filco) cost ~50USD at MOQ
So, everything above this is probably win margin and costs for import/shipping/whatever!
« Last Edit: Tue, 22 September 2009, 12:52:39 by TheSoulhunter »
Offline itlnstln
« Reply #22 on: Tue, 22 September 2009, 12:54:17 »
I could bear those prices.
Offline Hofy
  • Voids Warranties
« Reply #23 on: Fri, 25 September 2009, 22:55:14 »
What little time I had at home this week to play with the new num pad I have figured out that the linear switches are not for me.  Not even for gaming.  I am so used to some sort of tactile response that the black Cherry switches are as bad as rubber dome membrane keyboards to me.
Cherry ML4100
Offline AndrewZorn
« Reply #24 on: Sat, 10 October 2009, 16:25:04 »
awwww
could have been the perfect "gaming pad"
might still get it
cause 2kro black should be better than 2kro brown
then again
is it 2kro minimum (well, as its normally expressed) or 2 everywhere?
if i can WA + crouch/run with something in the corner it might still be worthy
(as a 2kro filco can still use modifiers)
Offline SirClickAlot
    • http://www.mrinterface.com
« Reply #25 on: Sun, 16 January 2011, 08:07:29 »
Aha! Ripster officially beat me to it with the Switch Try Numpad ... :-)
[Succes is when you get what you want
Happiness is when you want what you get]
Optimize your interfaces : http://www.mrinterface.com
Currently using( not necessarily my favorite : I iterate over my collection many times ):
Filco White Majestouch Mx Brown DS White on Black.
Looking for : New and interesting interfaces. Working on :www.deskthority.net
Offline Phaedrus2129
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
« Reply #27 on: Sun, 16 January 2011, 09:43:14 »
Yeah, I noticed that after looking more closely too.
« Reply #28 on: Sun, 16 January 2011, 09:43:53 »
Quote from: ripster;279401
Looks rubber dome.  I think half the HK Ebay listers don't speak English so just copy and paste.
I agree : those are highly likely just rubber domes... Sadly, since the price is lower than the shipping costs! :-)
Regards.
Offline kaiserreich
  • HHKB Elite
« Reply #29 on: Wed, 30 March 2011, 08:13:11 »
Sorry for digging this thread up from the grave.
I ordered the same numpad from the seller, paid via paypal to him on monday, but he has not sent it. Plus he is not replying to 2 messages I sent to him regarding the status of the shipment.
Just want to know if anyone can share their experience with this seller?
Offline Bern
« Reply #30 on: Wed, 30 March 2011, 09:42:15 »
I bought one of these.  Received the numpad without any problems.
Offline Reaif
« Reply #31 on: Wed, 30 March 2011, 14:08:03 »
I ordered one about a week ago. It should be arriving some time in April, or early May lol.
Currently own:
Das S Ultimate with Browns
Cherry G84-4100 with ML Linear switches
Memorex Telex with NMB Space Invaders
Leopold with Blues
Offline CephalicCarnage
« Reply #32 on: Wed, 30 March 2011, 17:27:49 »
Does anyone know if this keypad support an independent numlock state?
Filco Tenkeyless "Otaku" (Blue), Leopold Tenkeyless "Otaku" (Brown), Leopold Tenkeyless (Blue), Goldtouch GTC-0077 Numeric Pad (Brown)
In the mail: HHKB Pro2 White/Gray
WTB: G80-8113HRBUS-2 with Clear switches
« Reply #33 on: Wed, 30 March 2011, 17:51:58 »
Darn, so much for easy use with my laptop without having to fiddle with the numlock key.
Guess I won't be able to get away with buying a cheapo numeric keypad.
Offline Tranquilite
« Reply #34 on: Wed, 30 March 2011, 19:55:46 »
I ordered one of these, along with a some of the other switch types from Mouser. All so that I can make a more educated guess as to what I want for my first big cherry MX keyboard purchase.
Offline kaiserreich
  • HHKB Elite
« Reply #35 on: Fri, 15 April 2011, 08:57:02 »
Does the wide cherry logos on this means these are the old Cherry MX blacks instead of the newer ones?
Offline .XL
    • http://www.paokfc.gr/
« Reply #36 on: Fri, 15 April 2011, 16:56:45 »
Quote from: kaiserreich;331326
Does this actually matter? It's a $15 numpad with Cherry switches...they can salvage them from the dump for all I care :p
Keyboards: Filco Majestouch-2 87key Browns - Realforce 103UB 55g - Compaq MX11800 (ghetto clears + doubleshots)
Offline kaiserreich
  • HHKB Elite
« Reply #37 on: Fri, 15 April 2011, 20:58:09 »
By Old MX blacks, I do not mean that they are from the dump or anything of that nature, but rather I meant it in the way that they are the older version of the MX Black.
Sixty mentioned it in deskthority here about the MX blacks with wider(old type) and narrower(new type) Cherry logos and how they feel, not that I have tested the MX Blacks with narrower logo anyway. I thought I came across more posts regarding this somewhere in that forum but this is the one I could find for now.
EDIT: I guess what I was trying to ask previously was whether the MX Blacks on this Numpad is the newer or the older type based on the size of the Cherry logo. But, unfortunately, I had people confused as to what I meant by old and new due to the poorly worded response that I wrote previously.
« Last Edit: Fri, 15 April 2011, 21:04:40 by kaiserreich »
Offline Corland
« Reply #38 on: Fri, 15 April 2011, 21:27:21 »
Got one of these this week- the switches all feel brand new. there's no stabilizers in the larger keys, so they are very wobbly when not hit right on the switch. But for 15 bucks, it's certainly worth it.
Offline curzen
« Reply #39 on: Mon, 09 May 2011, 20:51:46 »
poop, these seem to be gone :/
[ KBC Poker ]
Offline godofdeath
« Reply #40 on: Mon, 09 May 2011, 23:08:58 »
awww i thought there was a new listing for these things
i shoulda gotten one when i could have
Offline kaiserreich
  • HHKB Elite
« Reply #41 on: Tue, 10 May 2011, 00:59:54 »
http://cgi.ebay.com/Mechanical-Number-Pad-Keypad-Brown-Switch-Mac-/400101801779?pt=PCA_Mice_Trackballs&hash=item5d27ecff33
here's an alternative. Cost twice as much, comes with MX Browns from what I understand of the description
Offline godofdeath
« Reply #42 on: Tue, 10 May 2011, 01:02:08 »
says for macs only and also the usb is ridiculously short
Offline curzen
« Reply #43 on: Tue, 10 May 2011, 06:52:13 »
don't see why it would be mac only. the bezel around it is somewhat stupendously big though.
[ KBC Poker ]
