Author Topic: IBM Model M2 key rollover?  (Read 5185 times)
Offline TheSven
« on: Sat, 24 January 2015, 08:31:30 »
I've got a broken Model M2 (bad caps), and I wanted to know what the key rollover is for it. Is it 2 like the regular Model M, or higher?
Thanks.
Offline 0100010
  • Not Sure
Re: IBM Model M2 key rollover?
« Reply #1 on: Sat, 24 January 2015, 12:45:44 »
2KRO
« Reply #2 on: Sat, 24 January 2015, 17:03:32 »
The M2 has buckling spring over membrane, just like the Model M. The springs/hammers are identical but the barrels are shorter, with shorter keycaps and the keys are all in one plane, not mounted on a curved backplate.
Offline TheSven
« Reply #3 on: Sun, 25 January 2015, 08:32:56 »
2KRO
Aww that's a shame. I heard there's a mod to put some kind of copper sheet in the KB to make it NKRO? Are the Unicomps 2KRO as well?
Offline 0100010
  • Not Sure
« Reply #4 on: Sun, 25 January 2015, 08:50:54 »
Yes, Unicomps are 2KRO as well.
If you want NKRO in buckling spring, you need to go Model F.
Offline TheSven
« Reply #5 on: Sun, 25 January 2015, 10:40:50 »
What about this mod then, how do I perform that?
Offline 0100010
  • Not Sure
« Reply #6 on: Sun, 25 January 2015, 15:09:41 »
(It helps if you give a timestamp of when in the video they are discussing what you are referring to, especially when the video is an hour long.)  There is a thread for this, but I was not aware anyone had completed the work.  Will find and post.
Offline 0100010
  • Not Sure
« Reply #7 on: Sun, 25 January 2015, 15:19:20 »
This thread has some work on a custom Model M membrane that could incorporate diodes to allow for NKRO, around reply 87 or so.
https://geekhack.org/index.php?topic=40111.60
Offline TheSven
« Reply #8 on: Mon, 26 January 2015, 02:20:19 »
It was supposed to be around 44:00 I think, the link worked for me and started at that time.
