Author Topic: Custom SuperFlower PSU cables @ PEXON  (Read 82677 times)
Offline pexon
  • * Moderator
  • El Jefe of Sleeving
    • Pexon PCs
« on: Sat, 24 January 2015, 15:42:04 »
Hi guys,
I am not sure if you get SuperFlower PSUs anywhere outside of the UK? Overclockers in the UK stock the whole range of PSU cables (http://www.overclockers.co.uk/productlist.php?groupid=701&catid=123&subid=2057). We've made a couple of sets of PSU cables for the guys over at Overclockers for their 8pack branded systems (http://www.overclockers.co.uk/productlist.php?groupid=43&catid=2724).
SuperFlower PSUs are awesomely efficient, low noise, well priced and offer amazing flexibility with 11 connectors that are universal and allow SATA, Molex, EPS and PCI-E cables in the same terminal on the PSU side, this means you can have 6x PCI-E cables, 2x EPS cables, 3 SATA and 2 Molex chains as well as the 24 pin powered off a single PSU.
I can now offer a fully bespoke service for these PSUs, just like I can for Seasonic, Silverstone, Corsair, etc.
Link to store page:- http://pexonpcs.co.uk/products/superflower-psu-cables
Link to example of SuperFlower bespoke PSU cables:- http://imgur.com/a/oPXxX / http://imgur.com/a/IckYE
« Last Edit: Sat, 24 January 2015, 15:58:30 by pexon »
Offline Badwrench
  • ummmm.....I forgot
Re: Custom SuperFlower PSU cables @ PEXON
« Reply #1 on: Sat, 24 January 2015, 16:18:49 »
Very nice.  I wish we could get the Super Flowers with those connectors in the US.  We have to make do with rebrands by evga and rosewill which are basically the previous gen super flowers.  I was just researching psus to replace my aging CM 700 silent pro.  I ended up with a Seasonic X650 as it ends up being almost platinum rated and replacement cable sets are readily available so that i can do my own sleeving.  By the way, I really am liking the Telios sleeving.  Going to be doing mine in black/dark grey/light grey for a nice monochrome look.
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #2 on: Sat, 24 January 2015, 16:58:22 »
Yea the clear connectors are super awesome, they even light up when there is power going through the connector. SuperFlower have a patent for the connectors too, so you cannot purchase them.
I am loving Teleios sleeving, MDPC-X has always been my favourite but it requires a lot of work to get just right. The Teleios light and dark grey are particularly nice
