Author Topic: Poker II for android?  (Read 1574 times)
Offline roaming pear
  • THE Roaming Pear
« on: Sun, 25 January 2015, 15:51:00 »
Any ideas on how I can program the programmable layer of poker II for android?
Thanks
Does anyone have any accessories or key caps or other poker 2 related things lying around that they are not using?  I don't mind taking it off your hands if you no longer want it...
Re: Poker II for android?
« Reply #1 on: Sun, 25 January 2015, 17:59:14 »
My poker II works great on android. I'm using it now to type this post.
PNlayer is set to Dvorak and I'm on it now.
What were you needing again?A USBOTGcable or something?
  • THE Roaming Pear
« Reply #2 on: Sun, 25 January 2015, 20:39:44 »
I have the OTG cable.
This might sound confusing, but I'm not sure how else to explain it...
I want to program the PN layer and I don't know how.  On windows, I can press windows, then type notepad, then press enter, and assign that to a key.  On android, when I search, I can't just press enter and go to the program.  If I press enter, it just does a search..
Offline Oobly
« Reply #3 on: Mon, 26 January 2015, 02:44:23 »
The problem is not how the keyboard works, but rather how the operating system handles launching apps.
I think you need to install a text-based launcher like Doorways or Terminal launcher.
Terminal launcher will allow you launch a program using a "." before the name, so you can program a macro on the PN layer for ".badpiggies" to launch "Bad Piggies" I think.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
