Author Topic: PBT replacement keycaps for full size Filco  (Read 2749 times)
Offline Special K
« on: Mon, 26 January 2015, 12:17:24 »
I like my Filco and have been using it as my primary keyboard at home for the past 5 years, but the keycaps are a weak point.  The lettering and matte finish is fading in proportion to key use, and in some cases is completely gone.
I've done some searching on here and it seems to be the case that PBT keycaps are more durable and won't fade vs. what a Filco uses by default.
Where can I get a full set of black PBT keycaps with text printed on the top face that will work with a Filco?  I did a few Google/GH searches, but all the results I could find were for other keyboards (TKL, blank keys, etc.) or were sold out.
Are there any other users of full size Filco keyboards on here that have replaced the stock keycaps?  If so, what did you use?
Filco FKBN104MC/EB
Filco FKBN104M/EB2
IBM Model M 1391401 - 11/13/87
Quote from: ripster
LOL - we're on post #163 of this mega-thread and you've gone from"keyboard n00b" to "keyboard sn0b".  We've done our job.
Offline FreeCopy
Re: PBT replacement keycaps for full size Filco
« Reply #1 on: Mon, 26 January 2015, 12:46:52 »
There was this on Massdrop but it just ended. I think the set was around $40?
https://www.massdrop.com/buy/vortex-pbt-keycaps?mode=guest_open
Also check here: http://mechanicalkeyboards.com/shop/index.php?l=product_list&c=40
I'm currently using Hyperfuse DSA
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
