Author Topic: Issue with FN layer on converted Model F  (Read 1347 times)
Offline faceyourfaces
« on: Mon, 26 January 2015, 16:46:43 »
On my Model F converted with xwhatsit's controller, pressing FN+a number will cause either the function or the number pressed to be spammed multiple times, making it difficult to use them as F keys. For example here is the output of pressing Fn1 and the number 7 on my keyboard, which should only be F7:
777777777777777777777777777777777777777777777777777777777777777777
Anybody know how I can fix this issue? Any help would be appreciated.
Offline 0100010
  • Not Sure
Re: Issue with FN layer on converted Model F
« Reply #1 on: Mon, 26 January 2015, 19:36:26 »
Do you have the function key programmed to be the same key on both the base layer and the function layer?
« Reply #2 on: Mon, 26 January 2015, 20:48:01 »
No, thank you so much for the fix!  :D
