Author Topic: Poker 2 case screw placement? Helped :)  (Read 2938 times)
Offline nandop
  • May your keystrokes always be true.
« on: Mon, 26 January 2015, 21:12:33 »
I saw a picture somewhere with the dimensions to where the screws are for a poker 2 PCB/GH60 PCB. I have been looking for about half an hour and can't find any info relating to that. Can someone help me please?  :)
« Last Edit: Fri, 30 January 2015, 17:14:28 by nandop »
Sprit 60%, White MX 78g Au | Planck Ortholinear 40% Clear MX | Phantom TKL Browns 110g Au
Re: Poker 2 case screw placement? Help!
« Reply #1 on: Mon, 26 January 2015, 21:44:59 »
Matias posted that image, let me search for it.
Edit: I can't seem to find it right now, but I'm pretty sure I have a copy on my PC at work. I'll check tomorrow morning, if no one finds it before then.
« Last Edit: Mon, 26 January 2015, 22:09:18 by jdcarpe »
Offline user 18
« Reply #2 on: Mon, 26 January 2015, 22:34:43 »
Avatar by ashdenej
« Reply #3 on: Mon, 26 January 2015, 22:40:57 »
https://geekhack.org/index.php?topic=66787.0
Second post in this thread?
Oh geez, it was obra. My memory failed me!
Forgive me, Jesse. :)
Offline nandop
« Reply #4 on: Fri, 30 January 2015, 12:04:37 »
What a life safer!!! Thanks guys!!!! There was a measurement I was off, thank you thank you thank yiu
