Author Topic: [IC] Gateron Switches  (Read 186774 times)
Offline Ngt
Re: [IC] Gateron Switches
« Reply #250 on: Sat, 14 February 2015, 09:22:35 »
I wondered if the gateron clear stem is smoother than the gateron black stem. I harvested the spring of the MX black and transplant it into the gateron clears to see if it feels smooth only due to the light spring or if the stem was smoother as well. The gateron black is smoother than the 60g gateron clear I just made. However I wonder if by opening the switch and manipulating the stem, I didn't remove the stock lube they put on it (if there is some). If it is the case, then my experiment is worth nothing.
« Last Edit: Sat, 14 February 2015, 09:27:16 by Ngt »
Offline snipars
« Reply #251 on: Sat, 14 February 2015, 09:36:33 »
Tyrone knows a thing or two about girth, his testimonial is definitely true
Duck Octagon + Gateron Black |HHKB Pro 2 | Poker 2 + Vintage Black + Tex case | Unicomp Ultra Classic | WASD V2 |
Offline greath
  • A waffle is like a pancake with a syrup trap.
« Reply #252 on: Sat, 14 February 2015, 09:48:17 »
Maybe clean them both, then add the same amount of the same type of lube (if any)?
Offline Ngt
« Reply #253 on: Sat, 14 February 2015, 09:57:03 »
Yeah that'd be the way to do it. However I haven't received my package from EK yet so I don't have any lub on hand. I'll have to wait for it. Do you need a special solvent to clean them or just soap and water is enough?
Offline jacobolus
« Reply #254 on: Sat, 14 February 2015, 10:21:27 »
I’m pretty sure the scratchy part of MX linear switches is the bottom housing, not the stem.
Offline Ngt
« Reply #255 on: Sat, 14 February 2015, 10:48:11 »
You're probably right.
Offline Zeal
    • Zeal Generation Inc.
« Reply #256 on: Sat, 14 February 2015, 11:04:29 »
There's only a bit of lube on the legs of linear switches. Though the smoothness comes from the stem & bottom housing.
Offline foopod
« Reply #257 on: Tue, 17 February 2015, 04:02:21 »
Very keen to get my hands on some of the 35g clears.
Offline meow a cat
  • Resistance is futile.
« Reply #258 on: Wed, 18 February 2015, 08:01:44 »
In for 100 clears and 100 blacks! I love me some silky smooth linears.  :thumb:
Boards:
Offline monotagary
  • Keycaps > Rent
« Reply #259 on: Wed, 18 February 2015, 08:32:37 »
Looks like Massdrop put up Gateron switches today.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #260 on: Wed, 18 February 2015, 08:37:00 »
Yep, just saw that. so GB starting now
Offline Ngt
« Reply #261 on: Wed, 18 February 2015, 08:41:56 »
Shall we redirect to massdrop or are you still going to do a GB?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #262 on: Wed, 18 February 2015, 08:44:23 »
Still doing the buy, the post is just waiting on mod approval. These will, as you can see, be cheaper than Massdrop's, and at this point it's hard to trust their expected ship dates
Offline Fire Brand
  • Keeper of Rainbows
  • BISCUITS!
« Reply #263 on: Wed, 18 February 2015, 08:45:34 »
I was just going to ask that also, should be hang o for a GB here or go to massdrop :x also massdrops shipping is never great :/
Comment invalid just after I posted it :p
My Youtube Channel ~
Keyboards owned
My classified thread :3
Offline monotagary
  • Keycaps > Rent
« Reply #264 on: Wed, 18 February 2015, 08:48:14 »
Good job Hwood! at least a week ahead of schedule.  :))
Offline Moralless
« Reply #265 on: Wed, 18 February 2015, 08:48:46 »
I'd recommend to just participate in this GB. Given the horrible shipping history of MD, you'd probably end up getting the switches from this GB first
Offline Ngt
« Reply #266 on: Wed, 18 February 2015, 08:49:51 »
Yeah it is definitely cheaper here. Plus it would be a shame to let you down after all the hard work you dedicated to it.
Offline Ngt
« Reply #267 on: Wed, 18 February 2015, 08:50:33 »
Yeah my switch tester took 4 months to arrive. Well there was time for it to be made but still.
Offline Moralless
« Reply #268 on: Wed, 18 February 2015, 08:50:34 »
Also forgot that Big Tyrone is backing this GB so you know it's going to be a success  :thumb:
Offline Lpwl
  • lpwl.bigcartel.com
    • My O-ring Store
« Reply #269 on: Wed, 18 February 2015, 08:54:25 »
Massdrop was quicker than us !
EDIT :
130 pcs 120 pcs per bag
$34.99 (without shipping)
Blacks - 50g Linear
Blues - 55g Clicky
Clears - 35g Linear
Browns - 45g Tactile
Reds - 45g Linear
Estimated ship date is March 20, 2015.
« Last Edit: Wed, 18 February 2015, 09:48:05 by Lpwl »
Offline strict
  • TKL Zealot
« Reply #270 on: Wed, 18 February 2015, 08:59:07 »
Im so glad I was able to purchase my Gaterons from Zeal otherwise I might have been tempted to order from MD. I'll bet dollars to donuts they find a way to screw this one up just like everything else they do.  :))
Offline Fire Brand
  • BISCUITS!
« Reply #271 on: Wed, 18 February 2015, 08:59:56 »
Aha yeah sorry I posted that at the same time Hwood posted saying he would be starting the group buy here, never had a problem with massdrop though although the shipping is terrible for anyone outside the US, anyway will be in on this here rather than MD :)
Keyboards owned
Offline honoka
« Reply #272 on: Wed, 18 February 2015, 09:01:20 »
EDIT :
130 pcs per bag
Blacks - 50g Linear
Blues - 55g Clicky
Clears - 35g Linear
Reds - 45g Linear
Seems expensive, and with shipping to Sweden the price is almost the same as Cherry switches.
I wish I was in 'merica =(
« Reply #273 on: Wed, 18 February 2015, 09:08:23 »
Do gaterons lose smoothness if you swap the top half of the casing for cherry? I ask because my build will look a lot better with black switch tops. Also will this GB start dyspite MD?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #274 on: Wed, 18 February 2015, 09:28:18 »
It's a mild difference yes. And yes, the buy is starting now, just waiting for the thread to be approved by mods
Offline Sygaldry
  • Edema Ruh
« Reply #275 on: Wed, 18 February 2015, 09:28:32 »
EDIT :
130 pcs per bag
Blacks - 50g Linear
Blues - 55g Clicky
Clears - 35g Linear
Reds - 45g Linear
Well ****... I just bought 110 for about 65 USD.
Lesson learned in patience...
Anyhow... is the consensus out on whether the linear Gateronies need lube?
« Last Edit: Wed, 18 February 2015, 09:31:14 by Sygaldry »
null
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #276 on: Wed, 18 February 2015, 09:34:36 »
GB here: https://geekhack.org/index.php?topic=68943.0
And Sygaldry, the Gaterons are really smooth without lube, but lubing them really is an experience. And you know, you can always cancel a massdrop order ;)
Offline Sygaldry
  • Edema Ruh
« Reply #277 on: Wed, 18 February 2015, 09:41:14 »
Hmm well I guess ill be spending a few hours today or tomorrow (or the weekend... or whenever) lubing, stickering, and spring swapping (62g gold) the Gateronie Clears ill be getting from Zeal today. Then ill put the switches back in the bag to wait for a suitable keyboard to put them on.
null
Offline Synjin
« Reply #278 on: Wed, 18 February 2015, 11:53:53 »
Just curious if anyone has any idea how the contact on it will last since it looks like it is made of copper instead of gold plated like Cherry's? Patina might affect the feel overtime once the copper starts oxidizing.
Offline Zeal
« Reply #279 on: Wed, 18 February 2015, 11:57:35 »
Both Cherry & Gateron use gold crosspoint technology.
