Author Topic: Key function layout for HHKB Professional 2?  (Read 14264 times)
Offline dmbr
« on: Wed, 28 January 2015, 17:27:41 »
Just received my HHKB today and I'm struggling to figure out the corresponding keys for the FN key. I'm embarrassed to admit I can't even figure out how to use CTRL :/
Could anyone please provide me with a map of the keyboard's functions (FN+key = ) or a list?
Thanks so much in advance.
Offline Lurch
Re: Key function layout for HHKB Professional 2?
« Reply #1 on: Wed, 28 January 2015, 17:31:05 »
Quote from: Flyersfan1
Offline Moralless
« Reply #2 on: Wed, 28 January 2015, 17:36:28 »
Here's the image that I used to learn the hhkb layout, found it very helpful to print this out and have it under my keyboard so I can get access to it whenever I need. The keys on the front are the ones in the Fn layer. Please note that that the Vol+-, mute and eject keys only work in Mac OS.
Offline dmbr
« Reply #3 on: Wed, 28 January 2015, 18:01:30 »
Bless you guys.
But I'm confused...where's Ctrl???
 Cheers.
Offline snipars
« Reply #4 on: Wed, 28 January 2015, 19:23:03 »
Bless you guys.
 Cheers.
on the left
Duck Octagon + Gateron Black |HHKB Pro 2 | Poker 2 + Vintage Black + Tex case | Unicomp Ultra Classic | WASD V2 |
« Reply #5 on: Thu, 29 January 2015, 20:24:25 »
Control on the left side of row C, where Caps Lock is on some other keyboards.
And Backspace is generally just above Return (which I've just realised is primarily labelled Return rather than Enter), where \| is on standard ANSI layouts.
