Author Topic: Info on custom plates cases and caps needed  (Read 1994 times)
Offline cinnamonrollz
  • buckle master 5000
« on: Thu, 29 January 2015, 18:07:53 »
In short, A big edits needed here so ill just rephrase.
I'm taking a class where I get to build what ever I want with a plasma cam, makerbot replicator 2x and a cnc. Because of my interest in mechanical keyboards I choose to make a ton of cases and caps etc.
One of the first things I want to do is make some alps plates so any advice would be appreciated.
« Last Edit: Thu, 05 February 2015, 17:29:22 by cinnamonrollz »
Re: alps plate design help needed!
« Reply #1 on: Thu, 29 January 2015, 18:15:01 »
swill and jdcarpe might be able to help you out.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #2 on: Thu, 29 January 2015, 18:39:24 »
http://builder.swillkb.com/
second switch type from the left is alps compatible, though stabs will end up being MX type I believe.
« Reply #3 on: Fri, 30 January 2015, 16:13:44 »
with a 3mm cut it would be kinda hard to use the 2nd one. Plus I need to be able to model the plate in a cad program myself.
« Reply #4 on: Sun, 01 February 2015, 17:52:45 »
Looks like ill have to buy an at-101w or something
« Reply #5 on: Thu, 05 February 2015, 17:28:04 »
Im really glad the kerf on the plasma cam was actually 60 thousandths of an inch instead of 3mm. This makes alot of new options available
