Author Topic: NIB IBM Model M Europe Edition ISO  (Read 3086 times)
Offline infiniti
  • I <3 KB
  • Bob was here
« on: Fri, 30 January 2015, 10:18:09 »
Offline Touch_It
Re: NIB IBM Model M Europe Edition ISO
« Reply #1 on: Fri, 30 January 2015, 12:36:59 »
Probably not the best place to discuss this but when did IBM/Lexmark start using that style of sticker for the num lock lights?  I had always assumed it was for late model rubberdomes but clearly this isn't the case.
« Reply #2 on: Fri, 30 January 2015, 12:54:30 »
There are a lot of differences in the Greenock-made Ms.
The later ones had ABS spacebars with grounding straps, for one thing.
Ask someone who knows more about that factory than I do.
« Last Edit: Sat, 31 January 2015, 16:00:18 by fohat.digs »
- D Trump 2026-10-24
Offline POTV
« Reply #3 on: Fri, 30 January 2015, 14:20:12 »
Hi, I'm the seller.
Don't know that much about the inner parts, but the keyboard feels like the rest of my about 10-12 Model M's. The interesting thing, in my opinion, is the european / ISO key layout. They are not very common in NIB condition. I have a few for sale right now.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #4 on: Sat, 31 January 2015, 13:15:48 »
Really strange to me.  1391407 model number with a 42H1292 design.  The cord is permanently attached to it?  The date is right for the 42H1292.  Does it have a detachable cable?  This is very odd.
http://en.wikipedia.org/wiki/Model_M_keyboard
Danish/Icelandic 102 layout? ???
« Last Edit: Sat, 31 January 2015, 13:27:06 by Snowdog993 »
Offline Snowdog993
« Reply #5 on: Sat, 31 January 2015, 13:26:17 »
There are a lot of differences in the Greenock-made Ms. The later ones had ABS spacebars with grounding straps, for one thing. That rear label is printed directly on the plastic, it is not a sticker.
Fohat, that rear label is a sticker. The spacebar should be yellowed, I agree.  Unless they changed the type of plastic they used on the newer model?  I don't know.
Offline Snowdog993
« Reply #6 on: Sat, 31 January 2015, 14:08:29 »
The current Unicomps and the older 42H1292 keyboards have the same controller on the upper right side.  The membrane actually is different, but the keyboard is still buckling spring.  I would think the QT versions (Rubberdome) have the same controller too.  You have to be aware of that.  The model number is usually the giveaway.  In this case, it's an enigma.
Offline POTV
« Reply #7 on: Sun, 01 February 2015, 07:59:52 »
Regarding the cord: Yes, it is attached to the keyboard.
One other thing, I have noticed in my collection of danish ISO IBM Model M's: The cord on my 3 1995 editions are all coiled - with a smaller diameter than the usual coiled cord. I have only seen that on my own keyboards.
And as we are speaking of IBM Model M. I have noticed, that my 5 keyboards between 1986 and 1991 have a little less pingy feeling than the newer ones from 1991 and upwards. Perhaps it is due to the fact, that my newer ones all are NIB, while the other are used.
89384-0
Offline E TwentyNine
    • Some of My Keyboards
« Reply #8 on: Sun, 01 February 2015, 08:02:43 »
Note that the cable is flatter and thinner as well.  That's the standard construction on the M13 cables, as well as all the later fixed-cable M's.
« Last Edit: Sun, 01 February 2015, 09:04:57 by E TwentyNine »
Offline POTV
« Reply #9 on: Sun, 01 February 2015, 08:32:22 »
You're absolutely right about the M13 cable. I have just googled some pictures, thanks!
Offline Techno Trousers
  • ʘ_ಠ
« Reply #10 on: Sun, 01 February 2015, 11:48:38 »
The early Model Ms were made with a heavier steel plate, which tends to give them a more solid feel and could also help explain less pinginess than later versions.
