Author Topic: White blank keycaps  (Read 2212 times)
Offline berserkfan
White blank keycaps
« on: Fri, 30 January 2015, 10:37:07 »
Hey has anyone ever used these white blanks before? Any good?
http://www.ebay.com/itm/231402339096?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I'm thinking of getting some for a dye job, after which I enter (and hopefully win) kbd of the month.
I don't mind thin PBT, but I really mind these that are too tight on the stems.
Offline ynrozturk
Re: White blank keycaps
« Reply #1 on: Fri, 30 January 2015, 11:47:57 »
I am curious about these caps as well.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline yode
  • s a d b o y s
« Reply #2 on: Fri, 30 January 2015, 17:25:32 »
these look like the same exact set from Banggood. Apparently those aren't bad, not thick PBT but thin/medium.
300 OTF GBE OBLOCK ON BD
Offline FireInc
« Reply #3 on: Sat, 31 January 2015, 04:13:32 »
Packaging looks similar/identical to a 104 set I got off of geekkeys, only difference(other than cap count) being that the caps lock has an LED pass-through while mine do not.
From what little I've used of them(admittedly only mods; bought the set for a keyboard that hasn't been built yet) they seem fine. Not thick PBT but not all that thin, either. And quality-wise there weren't any issues, either.
Offline berserkfan
« Reply #4 on: Sat, 31 January 2015, 10:06:22 »
I actually want 104 but can't find that on ebay right now. Maybe since this is the weekend I"ll check out Taobao...
Offline drewba
« Reply #5 on: Sun, 01 February 2015, 13:22:31 »
Seconded. I used the geekkeys 104 PBT set as my first dye project yesterday. The Q row and number row are actually slightly thicker than the lower rows and should stay in the dye a bit longer.
