Author Topic: Unicomp full key set blank  (Read 2402 times)
Offline runcom
  • Topre lover
« on: Sun, 01 February 2015, 06:53:47 »
I was wondering which one of the provided options on unicomp website is the classical one, grey mods and pearl others http://www.pckeyboard.com/page/Buttons/KSET
Don't be a dumbass, always be kind to people, here and afk
Offline 0100010
  • Not Sure
Re: Unicomp full key set blank
« Reply #1 on: Sun, 01 February 2015, 21:48:54 »
Not sure what you mean by classical?
Standard IBM colors are pearl / pebble, and in a 101 key layout.  Note that you will have to also order the spacebar as well, you will want the 'large' size (7x width).
Unicomp also has keys available in black, grey or white (plus a myriad of other colors) in 104 (old style), 104 (new style), 103 and 105 key layouts.
101 and 103 use the large spacebar, both 104s use the small spacebar.
Offline intelli78
« Reply #2 on: Sun, 01 February 2015, 21:50:37 »
You want the pearl and pebble. And if it's for a genuine IBM board, order the large pearl spacebar to go with it.
Offline 0100010
  • Not Sure
« Reply #3 on: Sun, 01 February 2015, 21:50:58 »
This image shows the various bottom row layouts :
