Author Topic: Material and Print?  (Read 2078 times)
Offline Evrycard
Material and Print?
« on: Mon, 02 February 2015, 00:11:59 »
Anyone knows what material and print these keycaps are?
http://www.ebay.com/itm/PFU-PD-KB400KTW-Key-Top-Set-White-Happy-Hacking-Keyboard-HHKB-/301491257299?ssPageName=ADME:X:RTQ:US:1123
I emailed the seller and he has not clue yet.
Re: Material and Print?
« Reply #1 on: Mon, 02 February 2015, 00:12:26 »
Dyesub PBT.  Spacebar is ABS.
« Last Edit: Tue, 03 February 2015, 14:22:35 by nubbinator »
Offline jabbon
« Reply #2 on: Tue, 03 February 2015, 14:21:36 »
50usd? sounds about right!
Offline Oobly
« Reply #3 on: Wed, 04 February 2015, 02:56:30 »
As nubs said, dyesub PBT with ABS spacebar... Just to make sure, you are aware that these are not Cherry MX compatible? They're for Topre switches only, designed for the HHKB Pro 2.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
