Author Topic: O-Rings on Clears  (Read 2720 times)
Offline daerid
    • Rossipedia
O-Rings on Clears
« on: Tue, 03 February 2015, 01:26:27 »
Are sublime.
I have a set of about 90 50A-R o-rings that I tried on previous boards and hated. With the fury of a thousand fiery suns.
However, on the Clears... oooohhhhh yeah. That's nice as F**K. They really accentuate the tactility of the switch, and the reduced travel distance actually makes Clears feel lighter and more effortless to type on.
Highly recommended.
Offline Valen
Re: O-Rings on Clears
« Reply #1 on: Tue, 03 February 2015, 01:53:59 »
I agree, adding o-rings makes them feel lighter if you like to bottom out. You can try inserting 2 o-rings to further reduce the travel distance. I can use 2 with the smaller cross section o-ring but not with the larger one.
Offline Oobly
« Reply #2 on: Tue, 03 February 2015, 04:06:43 »
You should try soft silicone trampolines on 62g ErgoClears.... Mmmmm, good. Especially with some GMK Cherry or SA profile caps (any decently heavy keycaps, really).
I can't stand orings / trampolines on linears for some reason, though.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline PieterGen
« Reply #3 on: Tue, 03 February 2015, 06:11:12 »
I thought you did not bottom out on Clears? Because the spring gets very strong towards the bottom ?
Offline Oobly
« Reply #4 on: Tue, 03 February 2015, 07:28:47 »
It's easier not to because of the spring constant, but it still happens. It's not really THAT much harder at the bottom than Black springs.
Offline berserkfan
« Reply #5 on: Tue, 03 February 2015, 10:17:48 »
DO my jailhouse mod, you won't need clears any more.
Offline MGH
« Reply #6 on: Tue, 03 February 2015, 11:12:48 »
+1
Only reason to have clears is if you want in the middle actuation instead of at the top.
Offline flaming_june
« Reply #7 on: Tue, 03 February 2015, 11:16:15 »
I use o rings with black and I like them a lot.  I have to search for this jailhouse thingie.
Offline daerid
    • Rossipedia
« Reply #8 on: Tue, 03 February 2015, 11:18:41 »
I'll have to give it a shot. I absolutely can't stand Blues these days, but the jailhouse mod was always intriguing. They don't click anymore, right?
Offline MGH
« Reply #9 on: Tue, 03 February 2015, 11:23:15 »
Silent bump, even quieter than lubed clears. I'd say the bump is slightly less than clears but much higher than browns
Offline Dreamre
    • kbdlife
« Reply #10 on: Tue, 03 February 2015, 11:46:13 »
Lubed clears, lighter springs, o-rings and GMK goodness = love with every stroke...
Offline drewba
« Reply #11 on: Tue, 03 February 2015, 12:08:47 »
I found it. https://geekhack.org/index.php?topic=67984.0
FYI I found several "jailhouse" on geekhack if you need more detail or pictures.
Offline jabbon
« Reply #12 on: Tue, 03 February 2015, 12:17:45 »
tried on clears, didn't like it...atleast pcb mounted clears. I am now using panda clears (with vintage blacks spring) and I have to say that I love the typing feeling. Next step, to lube them.
Offline Oobly
« Reply #13 on: Wed, 04 February 2015, 03:24:24 »
I like my big bumps on ErgoClears, but I do like the sound of higher actuation point. I may have to try some. This is the only reason I would ever buy Blues! ;)
Offline Defect
« Reply #14 on: Wed, 04 February 2015, 09:28:33 »
Wait til you try Splash guard on clears
Unrivaled tactility.
Offline daerid
    • Rossipedia
« Reply #15 on: Wed, 04 February 2015, 11:00:35 »
What the f**k am I looking at there?
...and do they make it in tenkeyless?
Offline Defect
« Reply #16 on: Wed, 04 February 2015, 11:43:32 »
Mine came off a TG3 Data911 (cop keyboard with blacks.  Wonky layout)
I have two of these, cut one up to fit on a 60...and lost it.  Want to keep this one intact because I actually love my Data911 and may soon try blues + rubber.
Makes MX blacks feel similar to Topre, but with the upforce provided from the MX spring.  I love it.  Doesn't work with all caps though..
