Author Topic: How to make Function key act as Left Windows key on Filco Majestouch 2?  (Read 1565 times)
Offline mechanicalg33k
I just bought the Majestouch 2 Camo Edition and just realized that it does not have a Left Windows Key. Is there any way / workaround for the Function key to act as a Windows key?
Thank you so much!
Re: How to make Function key act as Left Windows key on Filco Majestouch 2?
« Reply #1 on: Tue, 24 February 2015, 07:32:51 »
nobody knows?? :(
Offline Jixr
« Reply #2 on: Tue, 24 February 2015, 11:23:22 »
Its a FN key, which basically means its hard wired to the controller.
What you could do, if you REALLY wanted the FN key to be a windows key, is jump the switch from the right windows key. It wouldn't act as a left windows key, ( windows sees that as two separate keys )  but it would do the job. And ofc, you'd loose your FN key. ( unless you cross jumped them to make the right windows key the FN key )
