Author Topic: [IC] Multi-Functional Steel Switch Holder - £10 Price Confirmed  (Read 16079 times)
Offline Dihedral
  • Mostly Harmless
« on: Wed, 04 February 2015, 11:35:05 »
Group Buy Thread. Go Here Instead.
Progress towards 20 Units
SketchUp Render of the finished item.
This is a versatile and attractive switch holder that should appeal to many members of the mechanical keyboard community.
[/center]
Specifications
  • Fabricated from High Quality Stainless Steel
  • Brushed Aluminium finish
  • Supports All MX / Alps compatible switches
  • Small and Portable
  • Versatile and Unique
Potential Uses
  • Switch Tester - try out different switches
  • Artisan Cap Display - store and show off your Cap Collection. Alternatively, an attractive option for cap makers looking to professionally show their wares.
  • Switch Lubrication and Modding station - a useful tool to streamline your modding workflow without taking up space like larger stations
  • DIY macro board - add a teensy for a stylish and customisable macro board.
Here is a render of what it will look like from OpenSCAD
The switch cutouts are from Swill's generator and therefore will definitely work as intended. For proof of this, see these 3D printed prototype cutouts.
Shipping to the US will be £5 untracked and £10 tracked.
« Last Edit: Fri, 27 March 2015, 09:11:23 by Dihedral »
Offline Dihedral
  • Mostly Harmless
Re: [IC] Steel Switch display / testing mount (To hold MX compatible Switches)
« Reply #1 on: Thu, 05 February 2015, 01:31:26 »
Bump Any interest?
« Last Edit: Mon, 23 March 2015, 06:29:51 by Dihedral »
Offline Data
« Reply #2 on: Thu, 05 February 2015, 08:09:56 »
So it's just a bent plate, basically?
I could go for one in polished stainless.  Think about doing one with 9 holes, 3x3.   :cool:
Offline Dihedral
  • Mostly Harmless
« Reply #3 on: Thu, 05 February 2015, 09:59:07 »
Yes, if you want to call it that :D
3x3 would be interesting but I like 4 because it represents how many fingers you hold on the home row on one hand.
« Reply #4 on: Thu, 05 February 2015, 10:00:57 »
I'm interested.
Offline strict
  • TKL Zealot
« Reply #5 on: Thu, 05 February 2015, 10:01:39 »
Any ideas on cost? I would be tempted to pick one up for the right price.
Offline Dihedral
  • Mostly Harmless
« Reply #6 on: Thu, 05 February 2015, 10:06:54 »
Would totally depend on the amount of people who ordered. I would like to do it for less than a fiver for one unit though.
Offline azhdar
  • Praise the AZERTY god
« Reply #7 on: Thu, 05 February 2015, 10:16:00 »
With the tool swill released, I think it's easier to just get it cut for yourself.
Azerty Propagandiste
Offline Dihedral
  • Mostly Harmless
« Reply #8 on: Thu, 05 February 2015, 11:11:21 »
I'd like to sell them for a small profit, as well as make them for myself.
Offline Data
« Reply #9 on: Thu, 05 February 2015, 22:24:14 »
At $5 each I'd buy 2 at least.
Offline Dihedral
  • Mostly Harmless
« Reply #10 on: Fri, 06 February 2015, 01:47:35 »
thanks for your interest.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #11 on: Fri, 06 February 2015, 07:47:57 »
This would be great for like a lube/sticker/spring swap station
Offline FrostyToast
  • Litshoard
« Reply #12 on: Fri, 06 February 2015, 07:50:28 »
I say that you should look into a switch cutout that can fit both MX and ALPS switches. You won't be able to have notches, however that shouldn't matter for a tester/lube station.
Quote from: elton5354
Offline Dihedral
  • Mostly Harmless
« Reply #13 on: Fri, 06 February 2015, 09:42:31 »
What shape hole can hold MX and Alps switches?
« Reply #14 on: Fri, 06 February 2015, 09:44:43 »
The one on the left. :)
Offline Dihedral
  • Mostly Harmless
« Reply #15 on: Fri, 06 February 2015, 09:46:59 »
Cool! I'll look into making a CAD file then.
« Reply #16 on: Fri, 06 February 2015, 09:49:03 »
Yeah, the ones from Swill's plate building tool with that shape should work just fine for both MX and Alps.
Offline Dihedral
  • Mostly Harmless
« Reply #17 on: Fri, 06 February 2015, 10:25:27 »
Swill says that this type would also work for alps. Is he right?
« Reply #18 on: Fri, 06 February 2015, 10:29:04 »
Swill says that
Yes, that's what I was trying to say, but I guess I wasn't very clear.
Offline Dihedral
  • Mostly Harmless
« Reply #19 on: Fri, 06 February 2015, 10:29:30 »
Swill says that
Great, thanks.
Offline Dihedral
  • Mostly Harmless
« Reply #20 on: Sun, 08 February 2015, 06:54:17 »
Added image to OP
Offline Dihedral
  • Mostly Harmless
Re: [IC] Steel Switch display / testing mount - now with images!
« Reply #21 on: Thu, 19 February 2015, 02:49:43 »
This will almost certainly get made, but if anyone else us interested speak up :)
Offline Dihedral
  • Mostly Harmless
Could come as a full switch tester - any interest?
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
I might be up for one if it could hold Alps switches :) . Already have a Cherry tester unit... What sort of shipping costs to the UK would this come down to roughly, you think?
Offline Dihedral
  • Mostly Harmless
I'm also in the UK so shipping should only be a couple quid or possibly even free. It should theoretically hold alps but it's using swills cutouts and some users have had issues putting alps on them.
Offline chyros
  • a.k.a. Thomas
Ah, if you're in the UK, that'd be very useful :) . Have you got a loose Alps switch that you could try it on?
Offline Dihedral
  • Mostly Harmless
I have 4 matias switches which I will try when I get a prototype.
Offline chyros
  • a.k.a. Thomas
Cheers mate, let us know - matiases should be representative enough for sure :) .
Offline Dihedral
  • Mostly Harmless
Sure :) should be on sale in around 4 or 5 weeks.
Offline 64rky
Only just saw this thread, I'd be totally interested as well (depending on price obviously).
Offline Dihedral
  • Mostly Harmless
Looking for maybe 5 pounds for just the unit, 9 or 10 pounds for the unit with switches and caps. Initially it will offer just matias switches though cherry is potentially an option too. Shipping will be fairly expensive, unless I can possibly get a US seller onboard for you guys.
Offline swornxin
    • Nailed Down Custom Pins
I would be 100% interested in grabbing one of these.  I find it to be much more difficult to swap springs when the springs aren't attached to anything.  It was much easier to do when they were soldered into my Phantom.
Octagon - 62g Cherry tactile greys
Phantom - 65g Cherry tactile greys
FC660M - Cherry blues
KC60 - Gateron browns
Offline Dihedral
  • Mostly Harmless
Awesome! Thanks for posting.
Offline mp101
Hi interested in 2 or 3.
Cheers
Offline Dihedral
  • Mostly Harmless
Cheers
Awesome :)
Offline taylordcraig
I'd also be interested in a 3x3 tester.
Offline Dihedral
  • Mostly Harmless
Thanks for your interest. Would you at all be interested in a 1x4?
Offline Fusion
  • Unknown Lurker
I'd definitely be interested in a 1x4 or any combination really, though I'm located in the US so it wouldn't be worth the overseas shipping at that point :P
Offline Dihedral
  • Mostly Harmless
Shame. Maybe I'll have to get a US distributer.
Offline Dihedral
  • Mostly Harmless
This is hopefully going to go into production - will be sold on etsy.
Register Interest formally here.
« Last Edit: Mon, 23 March 2015, 11:29:22 by Dihedral »
Offline Dihedral
  • Mostly Harmless
Seems like the ball is rolling - still a way to go until 20 units but america should be waking up now!
Offline Data
Did you mean to link to your spreadsheet in the interest check a few posts up?  The one in the OP links correctly to the Google survey.
Offline Dihedral
  • Mostly Harmless
I was using a spreadsheet but am now using a form. I will update that post though.
Offline KnivesM
Interested depending on price &shipping costs to US.
Others
Offline Dihedral
  • Mostly Harmless
Just looked it up with the royal mail, 5 pounds untracked and 10 pounds tracked.
Offline Dihedral
  • Mostly Harmless
Third of the way there, hopefully some artisan cap makers or other users can join in :)
Offline Dihedral
  • Mostly Harmless
Almost half way there guys :)
Offline Dihedral
  • Mostly Harmless
Added a new sketchup render to give you guys more of an idea of what the finished unit will look like.
Offline Dihedral
  • Mostly Harmless
I've sent off for quotes - if anyone knows any good UK companies then please tell me here or by PM :)
Offline Dihedral
  • Mostly Harmless
bump
