Author Topic: How long does it take you to swap key caps?  (Read 6511 times)
« on: Wed, 04 February 2015, 22:25:56 »
I'm sure this thread exists but I need to try out this keyboard I'm using so I wanted to type something up.
I just swapped caps from one realforce 87U to another realforce 87U and I'm thinking it took me around 15 minutes, that's with me playing with the space bar spring etc. And sitting on the couch listening to headphones at the same time so I wasn't trying to see how fast I could do it.
Just curious how long does it normally take you to swap a set of caps?
Maybe we should have speed runs, of course we wouldn't want any broken stems so please, swap caps responsibly.  :thumb:
Offline ideus
  • Björkö.
Re: How long does it take you to swap key caps?
« Reply #1 on: Wed, 04 February 2015, 22:27:21 »
Maybe the same here, but I only use under TKLs, so maybe I am slower than you.
Offline Zeal
    • Zeal Generation Inc.
« Reply #2 on: Wed, 04 February 2015, 22:33:41 »
Swapping unsorted blanks take the longest. Good thing Cherry POM caps have roman numerals underneath. ;)
Vortex blanks on the other hand...
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #3 on: Wed, 04 February 2015, 22:35:10 »
Yeah...if it's unsorted blanks...takes me a while.  Otherwise...dunno.  Should time myself.
Offline Moralless
« Reply #4 on: Wed, 04 February 2015, 22:37:08 »
I learnt this the hard way when I took my hhkb apart to lube it for the first time  :blank:
But yeah I think it takes me around 10-15 mins when I switching keysets around and a bit faster on boards with cherry stabilizers and not co star.
« Reply #5 on: Wed, 04 February 2015, 22:45:38 »
When it's set swappin' day it's also board cleaning day, so I usually spend a good 2-3hrs taking everything apart for cleaning and putting it back together again. This only happens like twice a year.
« Reply #6 on: Wed, 04 February 2015, 22:48:23 »
I'm just sitting here thinking other than my main daily driver I don't use my other keyboards long enough that they need cleaning.
Offline exitfire401
  • The Force is Re/\l
« Reply #7 on: Wed, 04 February 2015, 22:57:11 »
10 minutes at the longest for me. Thankfully, I have no blanks haha
« Reply #8 on: Wed, 04 February 2015, 23:35:32 »
I have never timed myself.  It is an interesting question to ponder.
Costar stabs takes me longer.  Also I tend to clean the keyboard while the keycaps are off.  And also take pictures during installation of the new set.
Offline Corey
« Reply #9 on: Wed, 04 February 2015, 23:58:28 »
Cleaned my key caps today and realized upon putting them back on that I have no idea where they even go. I can sit here and touch type but when it comes to knowing where each and every cap is I'm lost. It took me a while cause I was looking at a picture  :D
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #10 on: Thu, 05 February 2015, 00:26:58 »
« Reply #11 on: Thu, 05 February 2015, 03:11:30 »
I was wondering whether SpAmRaY actually asked the question to gauge the competition for this giveaway :))
Offline drewba
« Reply #12 on: Thu, 05 February 2015, 20:40:05 »
Thank you for the idea guys.
https://geekhack.org/index.php?topic=68459.0
:O Now there's an idea...
To answer the question though, I'm with Rowdy. I probably take about 15 minutes to remove everything but I end up lubing stabs, getting rid of dust and taking pictures. Real time ~1 hour?
Offline GenKaan
  • Mer caps, mindre käbbel
« Reply #13 on: Fri, 06 February 2015, 04:29:34 »
Taking off caps, cleaning them, drying them, cleaning the board (not taking it apart) and putting the caps back on takes a little over an hour for me. Never tried doing it as quick as possible, most of the time listing to a audiobook so I dont mind it taking some time
Going to put on some up tempo music and time myself next time!
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #14 on: Fri, 06 February 2015, 04:36:15 »
Too long. I have real trouble staying focused on tedious jobs so things like swapping caps usually takes me a few hours. It's one of the reasons I don't bother trying to do my own builds any more, soldering my GH60 probably took me 2-3 days and in the end I still needed to send it off for troubleshooting because of a diode that was soldered on backwards at the factory.
Which reminds me, I really need to take my Classic Beige set off my work board and give them a clean. Don't think I've cleaned them other than a quick wipe since I bought them :\
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #15 on: Fri, 06 February 2015, 09:00:50 »
A lot longer than that. Especially if a board has Costar stabs *shudder* or they inserts for the caps to go onto said stabilisers are over used and keep falling out *double shudder*
Usually with a keyset change comes a deep clean, so it takes me a while usually.
Offline azhdar
  • Praise the AZERTY god
« Reply #16 on: Fri, 06 February 2015, 09:11:24 »
I think it's a lot faster with the platic keycap puller than the wire type but it's way more agressive to the keycap.
Azerty Propagandiste
Offline HPE1000
  • Keycap Paparazzo
« Reply #17 on: Fri, 06 February 2015, 09:19:46 »
If the keycaps are blank, it takes some time, as everyone else says. But it takes even longer if the keycaps are cherry profile because, at least from my experience, those wire keypullers can dig into the keycaps and dent them. So if I am swapping out cherry profile keycaps, I usually use the wire keypuller for the 1x keys and then floss for the 1.25, 1.5+ size keycaps. That takes a lot of time, I have not timed it but probably 25 mins if they are cherry profile.
« Reply #18 on: Fri, 06 February 2015, 09:23:41 »
Don't hear too many people mention using floss that is interesting.
Offline HPE1000
  • Keycap Paparazzo
« Reply #19 on: Fri, 06 February 2015, 09:33:31 »
I use it every time I take off an artisan keycap that can't be pulled off with my hand. Much safer than any other way I have found.
« Reply #20 on: Fri, 06 February 2015, 09:40:53 »
I use this for pretty much everything
Offline monotagary
  • Keycaps > Rent
« Reply #21 on: Fri, 06 February 2015, 10:37:01 »
I swapped blank black keycaps for blank white/grey on my HHKB. Probably only took about 10 minutes since they were sorted, but I have taken off the blanks on my HHKB to clean it. I just left them in a big pile... putting them all back on took about 25 minutes since I had to resort them by row first.
Offline swornxin
    • Nailed Down Custom Pins
« Reply #22 on: Tue, 10 February 2015, 15:14:01 »
I would probably guess around 15 minutes.  Like someone else said, it's faster with Cherry stabs as opposed to Costar.  Maybe I will time myself next time I have to change.
Octagon - 62g Cherry tactile greys
Phantom - 65g Cherry tactile greys
FC660M - Cherry blues
KC60 - Gateron browns
Offline Cheese!
  • Cheese first, clacks later
« Reply #23 on: Thu, 12 February 2015, 17:55:33 »
Well...I start with all intentions just to swap the keys, then it becomes a full blown cleaning mission...so up to an hour and a half...then put another hour if I am watching a film. Efficiency is not my strong suit.
Offline BrewCaps
« Reply #24 on: Thu, 12 February 2015, 19:14:20 »
Usually in a BB halftime.
Offline base_on_base
  • Resident Hydroxide
« Reply #25 on: Thu, 12 February 2015, 22:06:10 »
I watch a movie while switching caps so ≈2 hours[length of the movie]. I could definitely switch keycaps faster than that but I'm never really in a situation where I have to replace a whole set quickly.
WASD V2 - MX Green / Aqua - MX Green(WIP) / Unicomp Ultra Classic - Buckling Springs
