Author Topic: Arrow led on Poker X  (Read 2531 times)
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« on: Thu, 05 February 2015, 02:57:07 »
Hello.
I am using Poker X. But It have trouble in recent times. That is led issue on spacebar; right shift; win right; menu & right control.
When I plug in cable, they always light. I can't turn off they when I use "Fn + Spacebar" except I draw cable out.
If anyone know way to fix, please help me.
Thank you very much.
  • Frenzy Classic.
Re: Arrow led on Poker X
« Reply #1 on: Fri, 06 February 2015, 08:21:19 »
No way?  :-[
Offline ideus
  • Björkö.
« Reply #2 on: Fri, 06 February 2015, 08:27:50 »
I have been using a Poker X for more than three years now, and I do not have any issue so far. Occasionally it repeats some letters, but I think that is due to the fact that the switches are very light and probably I type a little in the hard side. I have never had any issue with its leds. I cannot help you, sorry.
Offline Hzza
« Reply #3 on: Fri, 06 February 2015, 08:38:28 »
Do you have an aluminium case? If you do the LEDs might be shorting on it, I seem to remember mine did something similar.
edit - Sorry, the solution was to put an insulating layer between the PCB and the bottom of the case, I think I used some leftover underlay from some laminate flooring.
« Last Edit: Fri, 06 February 2015, 08:41:26 by Hzza »
  • Frenzy Classic.
« Reply #4 on: Fri, 06 February 2015, 08:42:42 »
Yes, no problem :).
I have that trouble, but it is no problem. But led issue is important problem with me because I always use arrow group.
If I can't fix it, I think I 'll desolder led & not need led there. So I am blind  :confused:
Anyway, thanks for your share.
  • Frenzy Classic.
« Reply #5 on: Fri, 06 February 2015, 08:49:14 »
Yes. I understand what you 're saying. But I tested PCB on mouse pad, arrow led is still light while ESC & Capslock led is normal.
I thought that is firmware issue. But I don't know how to flash firmware for Poker X.
« Last Edit: Fri, 06 February 2015, 09:21:44 by quochung1989 »
Offline DrHubblePhD
  • I am star stuff
« Reply #6 on: Fri, 06 February 2015, 08:56:55 »
You can try adding a layer of bath mat material under the PCB if it is shorting out.
Offline Hzza
« Reply #7 on: Fri, 06 February 2015, 09:03:27 »
Have you done any other mods to the board?
  • Frenzy Classic.
« Reply #8 on: Fri, 06 February 2015, 09:17:40 »
I don't think PCB is short-circuit. Maybe I 'll try desolder arrow led & resolder they after clean PCB carefully.
Yes sure. I assembled 38GT for my friend but there isn't any problem happen.
  • Frenzy Classic.
« Reply #9 on: Wed, 25 February 2015, 06:10:16 »
This is very sad for me. I can't fix it. I think transistor is died. So I use new one to instead. But I don't know about it. Who can help me?
Offline ideus
  • Björkö.
« Reply #10 on: Wed, 25 February 2015, 07:12:39 »
It is a shame your PkrX does not work well, mine is one of my favorites.
  • Frenzy Classic.
« Reply #11 on: Wed, 25 February 2015, 09:39:57 »
Yes, right. I hope I 'll receive everyone's help to fix it :)
