Author Topic: Possible Topre compatible keycaps  (Read 2022 times)
Offline Touch_It
« on: Sat, 07 February 2015, 12:15:07 »
I have 2 Apple Design keyboards.  Standard RD, don't have a use for them but based on some other threads it sounds like they may have compatible keycaps.
If someone could let me know if they are that would be great.  Also If they are I would be interested in selling though I have no idea about a fair price, but that might be a separate thread.
Re: Possible Topre compatible keycaps
« Reply #1 on: Sun, 08 February 2015, 02:55:04 »
The bottom one almost looks like the opposite of an Alps keycap.  Kinda like the slot on the top of an Alps switch that the keycap fits in to.
The top one you might imagine would fit a Topre board, but it would require both clips removed, and an irregularly shaped chunk carved out of each side of the barrel before it would even go close to a Topre keyboard (assuming it was even the right size).
« Reply #2 on: Sun, 08 February 2015, 02:56:33 »
Exactly what Rowdy said.  The top one would have to have stabilizers clipped and the cylinder would have to be modified.  The bottom one is turned 90 degrees from what it would need to be.
Offline Mandolin
  • Crystal Connoisseur
« Reply #3 on: Sun, 08 February 2015, 02:57:09 »
The top one is not a virgin.
Artisan keycap Maker
Working on
- Custom keycaps
- Artkeycaps V2 sale
- Due chihuahua and demoncat orders
- Boobiecaps
- Optic fiber embedded keycaps
- Others
Offline Touch_It
« Reply #4 on: Sun, 08 February 2015, 10:13:38 »
Hmm, I had also posted over on DT and it appears someone there has successfully used caps like these.  Topre gods are just begging me to get one :( lol.
Thanks Nover.  Forgot to link the thread :D.
« Last Edit: Sun, 08 February 2015, 11:06:16 by Touch_It »
Offline Nover
« Reply #5 on: Sun, 08 February 2015, 10:17:48 »
« Last Edit: Sun, 08 February 2015, 10:20:22 by Nover »
SSK, Ducky YOTD
