Author Topic: [IC] DANGER ZONE - A Key Set for Aviators and Their Wingmen  (Read 148254 times)
Offline Data
Re: [IC] DANGER ZONE - A Key Set for Aviators and Their Wingmen
« Reply #150 on: Sat, 02 May 2015, 19:26:57 »
That yellow enter goes perfectly with the set, I will definitely be using it
Here's the TKL Base Kit with centered legends.  Let me know if you see any errors.
This one also features the "final" custom legend design for the DZ Wing logo.
MUCH, much better buddy.
This what we're talking about, large legends, just like in any Cockpit and the Yellow stands out nicely.
Keep us informed when this baby is going to PMK for a buy up.
Thanks guys.
If you have Nuclear Data Green, the legends will closely mirror that set.  In other words, they'll be a little wider (stretched horizontally) than what I'm able to do in Illustrator, but about the same height.
Edit: I'm mainly talking about the alphas here.   :confused:
The biggest difference is the numbers, which I just realized today are totally different in the SP font than the original Gorton.  All but the 2, 5, and 0 numeral glyphs are different in SP's font.
« Last Edit: Sat, 02 May 2015, 19:39:20 by Data »
Offline Data
« Reply #151 on: Sat, 02 May 2015, 20:57:28 »
Here are the updated NumPad, Wingman, and AeroDox packs.
And here's a sample of what's possible with the ErgoDox using only the base kit and the AeroDox pack.
I'll make other samples like this once I have the remaining packs updated.
« Last Edit: Sat, 02 May 2015, 21:01:40 by Data »
Offline Snarfangel
« Reply #152 on: Sat, 02 May 2015, 21:05:22 »
Nice looking sets!
Offline Data
« Reply #153 on: Sat, 02 May 2015, 23:00:23 »
Here are the remaining packs updated with centered legends.
  It's hard to see in this image but the HUNT alphas are "bump" homing keys.
If these are error-free I'll update the OP with the new images.
I've got more sample layouts coming.  :)
« Last Edit: Sun, 03 May 2015, 00:11:39 by Data »
Offline Data
« Reply #154 on: Sat, 02 May 2015, 23:32:36 »
Here's an ANSI 104 "Plane Jane's" layout.
And one with novelties from the Wingman and Dogfighter packs.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #155 on: Sun, 03 May 2015, 00:02:15 »
I literally spunked at this pic, so fvckin' Gorgeous.
Offline Data
« Reply #156 on: Sun, 03 May 2015, 00:28:35 »
Here's a sample Atomic layout...
^ I think it would look a lot cooler with the yellow arrow keys from the Arrow Pack, but I wanted to just use base kit + Atomic/Planck Pack.
And my attempt at a JD40 layout using the keys JD recommended.  I think this is fairly close to what some people are using.
The full gallery is here:  http://imgur.com/a/UmDsa
Offline derezzed
« Reply #157 on: Sun, 03 May 2015, 00:32:54 »
The only way you could improve this set is to include a USB-powered glitter bomb that fires every time you press the chaff key.
Offline Data
« Reply #158 on: Sun, 03 May 2015, 00:59:48 »
Tempting.   :cool:
Here's an Octagon 75% layout using only the base kit and Maverick Pack.
Similarly, the Duck Lightsaver can be populated using a combination of Base Kit, Maverick Pack, and NumPad Pack.
Offline Elrick
  • Hype Master
« Reply #159 on: Sun, 03 May 2015, 03:09:15 »
Love everything you've done so far, just thought I would  make a request for all same coloured F1 to F12 keys, would that be at all possible?
Great if you could get options for all Dark Blue F1 to F12 keys and another option for all Grey F1 to F12 keys.
Offline Muffin860
« Reply #160 on: Sun, 03 May 2015, 08:37:57 »
Gah this set is just so well designed. I so hope it makes it to SP and tips.
IBM Model M
Offline Muffin860
« Reply #161 on: Sun, 03 May 2015, 08:40:37 »
IBM Model M
Offline Snarfangel
« Reply #162 on: Sun, 03 May 2015, 09:35:45 »
I second...er, third that thought. :)
Offline Oobly
« Reply #163 on: Sun, 03 May 2015, 14:35:22 »
I vote for full sculpt, Rows 1-1-2-3-4-4 (and Row 3 Shifts until SP has made the Row molds) like DCS, Cherry, OEM, etc. with centred Gorton legends.
There was already a vote and Row 3 SA won greatly
The vote only had 2 options, DSA or SA Row 3 and it was a big win for SA. AFAIK, Data was still open to discussing various SA profile options. Anyhow, just making my preference known.
That looks perfect. Loving it :)
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Data
« Reply #164 on: Sun, 03 May 2015, 14:52:09 »
Sure, I can do an alt function row kit.
Offline Data
« Reply #165 on: Sun, 03 May 2015, 17:16:41 »
Anything else?
Offline Elrick
  • Hype Master
« Reply #166 on: Sun, 03 May 2015, 20:58:46 »
Geez, love you man   :thumb: .
Just let us know when you'll put this baby up at PMK's site.   Have a feeling this will move like a real Jet Plane across the key-set hungry addicts, like here at Geekhack Central  8) .
Offline Elrick
  • Hype Master
« Reply #167 on: Sun, 03 May 2015, 21:01:29 »
Anything else?
I'm shaking with great trepidation like a Virgin at his first Orgy.     Can not wait for this to start already........
Offline Data
« Reply #168 on: Mon, 04 May 2015, 08:39:25 »
Anything else?
I should have an update on that later tonight (US Eastern).
What about the AeroDox and Planck/Atomic packs?  Am I missing anything?  What about 60% layouts?
« Last Edit: Mon, 04 May 2015, 08:42:01 by Data »
Offline Muffin860
« Reply #169 on: Tue, 05 May 2015, 06:54:30 »
Anything else?
Someone over on reddit had asked for an iso kit. Not sure if you saw that or not.
IBM Model M
Offline Data
« Reply #170 on: Tue, 05 May 2015, 08:32:43 »
Anything else?
ISO is the RAF Pack (UK).  That's the only ISO I'm comfortable doing.  If there's broad support for another language pack then they need to speak up, in here, and tell me exactly which keys need to be in it.  But I'm not doing DE, Nordic, or whatever for 2 or 3 guys because it won't tip, and there's no point.
Look at the last 7 group buys run on PMK.
Symbiosis - NO TIP
1976 - German TIP; UK NO TIP
Evergreen - NO TIP
Think Different - NO TIP
Deep Space - NO TIP
EVE - NO TIP
Green Tea - NO TIP
ISO kits don't tip.  If Euros want their special keys then they need to start supporting more GBs.  I don't know what else to say.
Offline Muffin860
« Reply #171 on: Tue, 05 May 2015, 08:39:51 »
Makes sense to me, thanks.
IBM Model M
Offline Data
« Reply #172 on: Tue, 05 May 2015, 22:59:28 »
I've submitted the formal Interest Check for approval on PMK.  I'll run the images/legends by Melissa one more time tomorrow, and we should hopefully see the IC appear on the web site in the next 24 hours.  Fingers crossed.  If we get the votes I'm in position to move forward on this closely following Matt3o's SA Retro.
Offline amnesia0287
  • Formerly Amnesia
« Reply #173 on: Tue, 05 May 2015, 23:37:58 »
I must have these. I will buy a board just for them. WANT.
PS. Amazing work  ^-^
Offline Data
« Reply #174 on: Wed, 06 May 2015, 08:16:17 »
Updated OP with the latest info.
Thanks.  :thumb:
Offline Muffin860
« Reply #175 on: Wed, 06 May 2015, 09:18:42 »
With the new Larger legends, can we increase the size of the legends on the F row to match? Obviously keys with shift characters will have a to be a bit smaller, but I think it would look more even if we increased the size of the F row legends as well.
IBM Model M
Offline Data
« Reply #176 on: Wed, 06 May 2015, 10:34:09 »
I considered it earlier, but I think they're as big as they can get given the limits of SP's fonts.  Look at some of the user photos from Pulse, Nuclear Data, Hacked by Geeks, or any other recent SA group buy.  The next font size up is the HUGE font used on the alphas and the mono-legend numpad set.  You can't fit 2 characters on a cap at that size, so doing the F-row that way is out of the question.
SP doesn't have unlimited font sizes.  If we go up a step for the F-row then we're looking at all new custom legends for the whole row, and I don't think this set justifies the huge increase in price.
It was a good idea, though.  :)
Offline Steezus
  • Keeper of Facts
« Reply #177 on: Wed, 06 May 2015, 20:55:22 »
This is a really nice set, I'm interested.
Offline Muffin860
« Reply #178 on: Mon, 11 May 2015, 08:13:11 »
Almost one week, but I still don't see the IC on PMK. Any word?
IBM Model M
Offline Data
« Reply #179 on: Mon, 11 May 2015, 09:48:58 »
Nope.  No reply from Melissa either.  It still shows "pending" on the PMK interface.  I'll ping her again tonight to see what's up.
Offline Elrick
  • Hype Master
« Reply #180 on: Mon, 11 May 2015, 20:48:51 »
Get the feeling that PMK is packed solid with orders and they are finding it hard to keep up with all the new key-set requisitions being placed  :-\ .
Offline Data
« Reply #181 on: Tue, 12 May 2015, 14:32:38 »
Yeah, I may have waited a few days too long.  :(  Honestly all they have to do is accept/publish my Interest Check.  I formatted it super neat.  I don't really understand the delay.
Offline Data
« Reply #182 on: Tue, 12 May 2015, 14:51:20 »
Offline Elrick
  • Hype Master
« Reply #183 on: Tue, 12 May 2015, 23:28:28 »
Nevermind, it's up.   :p
http://www.pimpmykeyboard.com/deals/danger-zone/
Just voted for it  8) .
Really love the way the Yellow Legends POP out at you like it will in any cockpit.  It's particularly useful in dark situations late at night, the keyboard becomes even easier to see and use.
PLUS it's a unique Colour-way, yet to be used here on Geekhack  :thumb: .
Offline Muffin860
« Reply #184 on: Wed, 13 May 2015, 08:56:11 »
I have notified everyone on reddit that expressed interest, as well as made new posts about the IC. I am making this set my personal mission. I really want to make it happen!
IBM Model M
Offline Muffin860
« Reply #185 on: Wed, 13 May 2015, 13:25:12 »
Up to 72 votes in under 24 hours! We can do this!
IBM Model M
Offline Data
« Reply #186 on: Wed, 13 May 2015, 15:10:44 »
Thanks dude.  Yeah, we're in good shape right now.  Hopefully the timing on the actual GB lines up well.  I'd prefer if we don't overlap SA Retro at all, or run concurrently with Jukebox.
Offline Steezus
  • Keeper of Facts
« Reply #187 on: Wed, 13 May 2015, 21:39:14 »
I sent my vote at PMK.
Offline Data
« Reply #188 on: Thu, 14 May 2015, 09:20:26 »
Offline Data
« Reply #189 on: Thu, 14 May 2015, 10:19:26 »
Just hit 100 votes.   :cool:
Offline Muffin860
« Reply #190 on: Thu, 14 May 2015, 10:26:09 »
AWWWWWWW YESSSSS  ;D! Now to sit and wait for the GB  :-[
IBM Model M
Offline Jolikki
« Reply #191 on: Thu, 14 May 2015, 14:17:23 »
1976 in the mail and i just voted for this.
Given how good the 1976 looks compared to the prototype pics, this will look awesome.
I need more keyboards...
"I would stand in line for this" - Moby
Offline Data
« Reply #192 on: Thu, 14 May 2015, 14:35:29 »
Yeah, I'm pretty confident the BFU and GSM combination is going to rock a lot of faces, after having stared at the color chips for hours.  Then when you add the YY legends it really pops like Mike Tyson.  I'm going to see if I can't get some better photos of the chips this weekend.
Offline Muffin860
« Reply #193 on: Sat, 16 May 2015, 12:37:48 »
Danger zone was in a featured email I got from SP today!
IBM Model M
Offline Data
« Reply #194 on: Sat, 16 May 2015, 13:20:18 »
I saw that.  Totally rad.   :cool:
Offline Data
« Reply #195 on: Sat, 16 May 2015, 14:24:38 »
Updated AeroDox Pack based on PMK feedback.
Based on earlier numbers from Melissa, I estimate this is about a $52 kit @ 25 MOQ.
Offline Elrick
  • Hype Master
« Reply #196 on: Sat, 16 May 2015, 19:46:15 »
It's being lined up in the PMK website window for future purchase  :thumb: .
Prepare your wallets for some major molestation and abuse because this Group Buy will go into serious territory quite soon.
Offline Snarfangel
« Reply #197 on: Sun, 17 May 2015, 18:54:02 »
I made an account on http://www.pimpmykeyboard.com/ just to vote for this. I like it a lot.
Of course it depends on the price point it comes in at (depending on which keyboard I pick for a makeover), but at a reasonable price, I will definitely get this.
(It would be nice to see on Massdrop, actually. It's more detailed and nicer to look at than 90% of the keysets offered, though that's just a personal opinion. Then again,I bought Miami, and I am still not sure if I drank a bit too much wine before I did that. :D ).
Offline Elrick
  • Hype Master
« Reply #198 on: Sun, 17 May 2015, 20:07:57 »
Hey don't worry about any previous choices you made whilst under the influence because sunshine, you should see the ones I went to bed with the previous night and woke up the next day, definitely nothing to be proud of there.  You just sneak away quietly but quickly so that no one else can see what you did.
For those looking to fill out a keyboard with these key-caps, well you can't go wrong with buying a WASD V2 barebone TKL or 104 because they offer them with a variety of authentic CherryMX switches, from Clears to Greens  8) .
Offline Data
« Reply #199 on: Tue, 19 May 2015, 19:15:02 »
Hey, OK, so...
The times they are a-changin' over at Signature Plastics.  You may have noticed that Melissa announced a new web site and interest check format for PMK over the weekend.  There are some pretty big changes ahead.  It looks like the entire "group buy" format we've grown accustomed to (if not necessarily loved) will be going away in favor of a more customer-centric storefront.  Here's the full quote for the motivationally challenged:
As most of you are aware, we have experienced many functional problems with the PMK website over the past year. This has not only been frustrating for you users but it has been equally frustrating for us as well. It’s time to make a change.
Over the next couple months we will be moving the site to a new platform. Hopefully this change will address the many frustrations you have experienced from lack of mobile access to simply checking out without any problems.
We also plan to make one major change to the site. The Interest Check and Group Buy format has been very successful, making some very creative designs available to a lot of people. Unfortunately we are seeing more and more of these great designs, many receiving hundreds of “like” votes, die during the 30-day Group Buy period. Under the new format we plan to still display designs in the Interest Check, but once they receive a certain number of “like” votes we will move the design into our production cue. Once produced, the sets will become available in our Key Shop where they can be purchased and shipped within days of ordering. This way you decide when to buy the keysets, minimizing the competition we are now seeing with so many new designs being launched at the same time. We would like to have at least 20 different custom designs available through our Key Shop.
And one more change. We plan to pay a 5% royalty on the net sales of each keyset design that is up for sale to the creator of the design. We feel the creative efforts that go into these keysets should be rewarded!
We thank you for your patience and support while we incorporate these changes. We also welcome any and all suggestions you may have on how to further improve the site.
Overall I think it sounds like an improvement.  So what does this mean for Danger Zone?
Well the way I'm reading it, the formal Interest Check that we have up now is going away, probably within the next 24 hours, as is the entire IC system.  They'll restructure it and put it back up in "the next month or two".  And from the wording Melissa used in her email it sounds like we'll be asked to resubmit our designs at that time... and basically start over.  From that point it gets easier, and presumably Danger Zone will be much easier to purchase once the new format is up and running.  I don't know much more than that.  I have a few questions of my own and I've already asked Melissa to clarify a few things for me.  I'll update the thread when I know more.
So... YAY!  New web site and format that hopefully doesn't suck, but also... BOO!  Starting over sucks huge donkey balls.
