Author Topic: Hebrew Model M  (Read 3088 times)
Offline jonathanyu
Hebrew Model M
« on: Mon, 09 February 2015, 23:19:21 »
Re: Hebrew Model M
« Reply #1 on: Mon, 09 February 2015, 23:36:24 »
It's been posted a few times before, but I think this is the first time it's close to reasonable territory.  It's been $150-200 with shipping in the past.
Offline Ludovician
Re: Hebrew Model M
« Reply #2 on: Tue, 10 February 2015, 05:10:45 »
I think this is a rubber dome keyboard. Someone else may be able to confirm.
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
Re: Hebrew Model M
« Reply #3 on: Tue, 10 February 2015, 07:18:42 »
It has been my experience that 71x and 72x Ms are rubber dome, and the 1-piece keys will not work on buckling springs due to non-hollow stems.
- D Trump 2026-10-24
Offline orihalcon
Re: Hebrew Model M
« Reply #4 on: Tue, 10 February 2015, 08:13:38 »
I asked him how much it would be for just the keycaps, and he said that the shipping would stay the same $87.53 to the USA, but that the item price would be free, so basically $10 less...  I thought it would more like $30-$40 in shipping by only shipping the caps, but apparently not.
Re: Hebrew Model M
« Reply #5 on: Tue, 10 February 2015, 08:38:03 »
If it was going the other way, the small flat-rate box from the US will hold a set of Model M keys (that is how Unicomp ships them) and I think that the international rate is about $25, and International Air Mail is usually about 2/3 to 3/4 of that amount, but their post may be different.
If this is a rubber dome M, the keys will be useless for a buckling spring IBM keyboard.
Offline orihalcon
Re: Hebrew Model M
« Reply #6 on: Thu, 12 February 2015, 00:17:18 »
Got this one for the opening bid from the same seller, this one should be buckling spring:
http://www.ebay.com/itm/121562448731
Part number is nothing special, but it's missing the escape key cap which shows that it isn't a rubber dome in the wrong case at least.
Shipping was $87.53, but I guess the auction price makes up for it. I think the same seller has listed some of these before, so he probably has access to more if anyone else is looking.
Offline Ludovician
Re: Hebrew Model M
« Reply #7 on: Thu, 12 February 2015, 00:52:18 »
Yeah, that's a 1391401 which is a buckling spring model. Good find.
Typing speed:
My collection:
Pending:
Infinity kit
Offline vivalarevolución
Re: Hebrew Model M
« Reply #8 on: Fri, 13 February 2015, 05:20:12 »
Thanks, been looking to transcribe the Torah for years now.
Re: Hebrew Model M
« Reply #9 on: Fri, 13 February 2015, 05:44:28 »
Wow! A Hebrew M! Can jew believe it!?
