Author Topic: Is there a Matte/Rubber paint/covering I can use for my case?  (Read 1368 times)
Offline Erraticape
  • Crooked French Canadian!
« on: Tue, 10 February 2015, 07:37:59 »
I currently have a Quickfire rapid and want to "paint" it white to match my monitor and peripherals. At the moment it seems to be covered in some sort of soft-touch matte paint. Is there a product I could buy that will replicate this soft-touch/matte stuff.
Re: Is there a Matte/Rubber paint/covering I can use for my case?
« Reply #1 on: Tue, 10 February 2015, 07:40:50 »
Plastidip?
Offline Nai_Calus
  • CLACK
« Reply #2 on: Tue, 10 February 2015, 08:09:44 »
Yeah, sounds like you want Plasti Dip: http://www.plastidip.com/
Do not go to their fan site the popup gives you if you want anything remotely useful, it's the worst-designed website I've seen outside of Geocities.
- IBM 4704 Model F 107-key "Bertha"
Other boards: Kinesis Essential, Infinity(G.Clears), Ergodox(MX Blues), Monoprice 9433
Eternally searching for Celestial Blue BS V2 and blue/purple Bros.
Offline Erraticape
« Reply #3 on: Tue, 10 February 2015, 11:23:26 »
Thanks for the link, this is exactly what I'll require.
Offline Synjin
« Reply #4 on: Tue, 10 February 2015, 11:23:53 »
Plastidip for sure imo.
Offline jamster
« Reply #5 on: Tue, 10 February 2015, 12:06:11 »
If you use the plastidip spray, apply multiple layers (4 should be safe) as it will be thick enough to remove it easily by peeling, in case you decide to get rid of it.
