Author Topic: Realforce 23U on Mac OS  (Read 2288 times)
Offline saturnotaku
« on: Tue, 10 February 2015, 09:12:35 »
Been searching for info on this but haven't been able to find a conclusive answer. Does the Realforce 23U work on Mac OS? I only need it to enter numbers and formulas in Excel and other programs. If someone can set the record straight, I'd appreciate it.
Offline exitfire401
  • The Force is Re/\l
Re: Realforce 23U on Mac OS
« Reply #1 on: Tue, 10 February 2015, 09:16:49 »
Mine works fine at work on OSX
Offline atlas3686
  • HHKB Elite
« Reply #2 on: Fri, 03 February 2017, 01:07:58 »
Is this still the case? Mine won't work at all on Sierra, a karabiner fix can get it working but it still has issues and has to be reconnected all the time to get it working.
