Author Topic: CAPS lock HHK Pro 2  (Read 6380 times)
Offline Evrycard
CAPS lock HHK Pro 2
« on: Tue, 10 February 2015, 12:47:28 »
Just go my HHK Pro 2 and love it.  ;D
One question for windows 7 users:
How do you do a CAPS lock?
fn + Tab doesn't do it.
Offline saturnotaku
Re: CAPS lock HHK Pro 2
« Reply #1 on: Tue, 10 February 2015, 13:04:07 »
Unplug your keyboard, flip dipswitch #1 to on, re-connect the keyboard, use fn+ tab, profit.
Offline Evrycard
« Reply #2 on: Tue, 10 February 2015, 13:20:38 »
DDDDDD ... THXXXX....  :thumb:
Offline TopreFan333
« Reply #3 on: Tue, 10 February 2015, 20:28:10 »
Also worth noting: many apps will let you format text as all-caps after you've typed it, potentially saving you some DIP-flipping.
Offline ImpendingxDoom
  • MF the SuperVillain
« Reply #4 on: Wed, 11 February 2015, 05:20:48 »
Spend some time going over what all the dip switches do. They make the HHKB surprisingly versatile and cusatomizable
Offline saturnotaku
« Reply #5 on: Wed, 11 February 2015, 09:52:09 »
I love the fact that it supports volume control in Mac OS X, and at least on versions 10.8 and 10.9, you don't need to install the drivers that EliteKeyboards has posted on its website.
Offline TopreFan333
« Reply #6 on: Wed, 11 February 2015, 11:14:59 »
I noticed last night that a couple of random keys (I think FN+O and P) actually make the brightness go up and down on my Macbook Air, weirdly. I don't have the Mac driver installed.
Offline saturnotaku
« Reply #7 on: Wed, 11 February 2015, 11:18:59 »
That's pretty awesome. I use mine with a Mac Mini so that functionality isn't available.
